Sub speaker cable. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-21-2012, 08:22 PM - Thread Starter
tmacka88's Avatar
Have found a few posts about this but none are a straight answer. What is the best cable to use for a sub, RG6, RG59, or a design sub cable.
Rg6 is designed for digital and is good with higher freq but it has 3 shieldings. 59 is used a lot for security video. And I'm not sure what type of cable they use in the sub designed cables.
Any ideas let us know
Cheers
tmacka88 is offline
post #2 of 10 Old 03-21-2012, 08:26 PM
oztech's Avatar
Liked: 101
On long runs I use RG6Q works like a charm.
oztech is offline
post #3 of 10 Old 03-21-2012, 08:45 PM - Thread Starter
tmacka88's Avatar
and short runs are just as fine?
tmacka88 is offline
post #4 of 10 Old 03-21-2012, 08:50 PM
oztech's Avatar
Liked: 101
Yes but I grab pre-mades at that point Monoprice has a good cable for the buck or if you want a little fancier Canare from Bluejeans has a very nice cable you can order to a specified length.
oztech is offline
post #5 of 10 Old 03-21-2012, 09:32 PM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
Plus 1 on the Monoprice cables.
Jeff
pronghorn/az is offline
post #6 of 10 Old 03-27-2012, 06:11 PM
Speedskater's Avatar
Quoted: 20 Post(s)
On long unbalanced analog interconnects (especially sub-woofer interconnects).
The best cables have a heavy braided shield (equivalent to 14AWG or larger).
Co-ax RG-6 cable is a very generic label, it simply means, a co-ax cable with a radio frequency characteristic impedance of 75 Ohms and an overall diameter of about 1/3 inch. On cable manufacture lists about 40 different models. Optimized for frequency or weather or fire code. RG-6 Quad Shield is definitely NOT what you want for audio cable, it is designed for cable TV frequencies.
Kevin
Speedskater is offline
post #7 of 10 Old 03-27-2012, 06:31 PM
oztech's Avatar
Liked: 101
There is no magic to it all thats needed is a 75ohm cable thats shielded it just has more uses than OTA or cable read the spec on this site RG6Q is 2 braids,2foils and a center conductor same wire we use Belden a lot. http://www.bluejeanscable.com/index.htm
oztech is offline
post #8 of 10 Old 03-27-2012, 07:11 PM
jsgrise's Avatar
Quoted: 185 Post(s)
Liked: 86
How much of a difference can it make? I'm asking this because I have 4 different types of cables connected from my AVR to my sub. One RCA cable from the receiver to the SMS-1, one 22awg rg59 cable from my SMS-1 to AB interconnect, one component cable from the interconnect to another interconnect and one Monster Sub cable from the interconnect to my VTF-15H...
Im I ruining it all??
Dedicated HT | DUAL 18" Dayton RSS460HO Custom Build | Sonus Faber Venere 1.5s | Sonus Faber Venere Centre | Sonus Faber Venere Walls | Marantz SR-7010 | Behringer iNuke 6000DSP | Velodyne SMS-1 | JVC D-ILA RS-46 w/ 128" 16:9 1.4 | Custom Bass Traps and Acoustic Panels (11)
jsgrise is online now
post #9 of 10 Old 03-27-2012, 08:49 PM
oztech's Avatar
Liked: 101
If it gets the job done without a hum or buzz then you are there and you would have noticed it when you ran the sweep.
oztech is offline
post #10 of 10 Old 03-28-2012, 09:48 AM
spyboy's Avatar
Liked: 47
RG6Q works just fine. As does RG6 and RG59. Perhaps Kal Rubinson, who writes for Stereophile, will chime in as he does sometimes in these cable threads.
spyboy is offline
