Sub selection for dedicated HT room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-23-2012, 10:27 AM - Thread Starter
rs691919's Avatar
Hi all...I need some help with sub selection for my soon-to-be started theater room. The link to my build thread is in my sig, the last post is the most current design iteration - two subs will be placed at the front of the theater behind AT fabric.
The room will be HT only (no music). I'm not into bone-rattling bass - tight and accurate and not neccesarily super loud LFE is more my inclination. Budget is flexible but I'd like to be in the $1000 range per sub (plus a single amp to drive both). I am getting pricing info on Klipsch THX Ultra 2 and Triad Bronze/Silver. Anything else I should look at? Thanks in advance!
rs691919 is offline
post #2 of 16 Old 03-23-2012, 10:42 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 166
Two of these with an amp. EP4000 should do fine. Then get a mini DSP for EQ and you'll be golden.
http://www.chasehometheater.com/inde...art&Itemid=135
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #3 of 16 Old 03-23-2012, 12:44 PM
JimWilson's Avatar
Quoted: 1564 Post(s)
Liked: 2084
A few others that might be worth considering are...
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #4 of 16 Old 03-23-2012, 12:56 PM
spyboy's Avatar
Liked: 48
HSU ULS 15 has lot going for it.
http://www.hsuresearch.com/products/uls15.html
Take a look at this, dual passive with a custom 800 watt DSP amp.
http://www.svsound.com/subwoofers/cy...&category_id=8
Chase Home Theater is as exotic as you need to consider.
spyboy is offline
post #5 of 16 Old 03-23-2012, 01:59 PM - Thread Starter
rs691919's Avatar
Thanks for the responses..I must confess that I'm a complete novice when it comes to subwoofers so forgive stupid questions.
With regards to the miniDSP...how does that work? Can the amp itself handle EQ or am I totally confused?
rs691919 is offline
post #6 of 16 Old 03-23-2012, 02:07 PM
eaamon's Avatar
Quoted: 74 Post(s)
Liked: 27
you might check the DIY section if you want to build it into a wall.
there is a lot of help there and you can get a lot of bang for the buck (like tight, accurate.)
or you might make a leather ottoman and hide 2 downward facing 18" subs in it and place it in the front middle of the room.
just some thoughts.
http://www.avsforum.com/avs-vb/showthread.php?t=1340095
2x18" or 2x15" this way you could hide and still get the bass you need.
eaamon is offline
post #7 of 16 Old 03-23-2012, 02:23 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 166
The mini DSP will do a lot better job eq'ing the sub than the AVR will. I don't think most room correction software goes below 20 Hz.
post #8 of 16 Old 03-23-2012, 03:01 PM - Thread Starter
rs691919's Avatar
just some thoughts.
Ugh. I am the antithesis of DIY unfortunately, but I appreciate the input, thanks!
rs691919 is offline
post #9 of 16 Old 03-23-2012, 03:03 PM - Thread Starter
rs691919's Avatar
Gotcha. Now if I were to bring in a professional calibrator at the end, could I forgo my own EQ unit?
rs691919 is offline
post #10 of 16 Old 03-24-2012, 11:39 AM
Auditor55's Avatar
I understand, if you're not into bone rattling bass and super loud LFE, why set up a dedicated HT. While tightness and accuracy is acherished attribute, I don't really think its critical for movies/HT, since audio is only 50 % of the film expirience.
I suspect that soundmixers will make soundtracks somewhat boomy intentionally.
Auditor55 is offline
post #11 of 16 Old 03-24-2012, 12:04 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 166
No, because he needs something to calibrate. The mini DSP does it automatically. If you hire a pro, then you would have something like a Behringer DEQ2496 or a Velodyne unit or something else i the loop. If you got one of the new Behringer iNuke DSP amps then you could have the amp and EQ in one unit.
http://www.behringer.com/EN/Products/NU3000DSP.aspx
post #12 of 16 Old 03-25-2012, 07:18 AM - Thread Starter
rs691919's Avatar
Well, exactly...audio is 50% of the experience. Video is important too. But also clarity of dialogue and effects. I know some people want the bass to blow them away -- I'm just not one of those people. Now, I don't want it to be whisper quiet -- I do enjoy the the big explosions, etc. It just doesn't have to crush me.
rs691919 is offline
post #13 of 16 Old 03-25-2012, 07:20 AM - Thread Starter
rs691919's Avatar
Understood. That's a pretty cool unit, not badly priced either. Thanks for the info.
rs691919 is offline
post #14 of 16 Old 03-25-2012, 09:07 AM
RMK!'s Avatar
Quoted: 1698 Post(s)
Liked: 1630
Audyssey MultEQXT32 is an exception to your statement. For most people in most rooms (including mine) it does a great job and, it EQ's the entire usable frequency range.
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #15 of 16 Old 03-25-2012, 02:04 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 166
I think xt32 only goes down to 20 Hz. Plus, it's on the more expensive AVR's. So if you get a cheaper AVR and get the iNuke amp then you can save a bit of money.
post #16 of 16 Old 03-26-2012, 08:41 AM
Adam-DiVine's Avatar
with that budget, I would go with a single Submersive HP. It looks like you have plenty of room behind the AT wall for the SubM to face side to side. With that sized room you will be very happy. If you are looking at Klipsch mains, the SubM will easily keep up with them. Obviously, if you are set on dual subs, this will not work. FWIW, I have a single SubM HP in a similar sized, treated room and have never looked back.
Adam-DiVine is offline
