SVS Vs. HSU: who gives the best mid-bass punch? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 43 Old 03-27-2012, 02:36 PM - Thread Starter
jsgrise's Avatar
Quoted: 180 Post(s)
Liked: 83
I was at the gun range last week and all I can say is, altough I'm not an acoustic specialist, mid bass or not, my chest felt a punch coming from the shots of my friend shooting his 30-06.
I agree that bass is exagerated in almost every movie, but so is the storyline, stunts, makeup, sets, decors, etc. Exagerated bass is ear candy and is a way of entrainement like it is to watch Megan Fox under the hood of Bumble Bee
Dedicated HT | DUAL 18" Dayton RSS460HO Custom Build | Sonus Faber Venere 1.5s | Sonus Faber Venere Centre | Sonus Faber Venere Walls | Marantz SR-7010 | Behringer iNuke 6000DSP | Velodyne SMS-1 | JVC D-ILA RS-46 w/ 128" 16:9 1.4 | Custom Bass Traps and Acoustic Panels (11)
jsgrise is offline
post #32 of 43 Old 03-27-2012, 03:19 PM
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Originally Posted by jsgrise View Post
Is your LFM-1 nearfield or farfield?
It's right next to the sofa. I just got the LFM and have been thinking about trying a different placement, I'm feeling more of the couch rumbling instead of the actual bass it seems.. have a Subdude on the way as well to isolate it from the hardwood floor.
BB1111 is offline
post #33 of 43 Old 03-27-2012, 04:35 PM
pokekevin's Avatar
Liked: 102
Originally Posted by BB1111 View Post
What does it feel like when a grenade or explosion goes off? I'm just trying to find what gives you that "punch" in real-life that would be missing in HT.
It doesn't feel good.
pokekevin is offline
post #34 of 43 Old 03-27-2012, 05:05 PM
SaviorMachine's Avatar
Liked: 90
Tight, punchy bass?
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #35 of 43 Old 03-27-2012, 05:07 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
What is the crossover to your LFM-1 set to?
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #36 of 43 Old 03-27-2012, 05:08 PM
capecodorthopod's Avatar
Originally Posted by Steve1981 View Post
Your system seems reasonably balanced and without significant gaps, so IMO it shouldn't need too much help from an MBM, although the MBM probably could deliver more output over its operating range and free up a little headroom for your sub. Of course, for the money spent, you could also look at an Epik Empire and sell the LFM-1.
I agree. You may be able to get what you want, or at least more punch than you're getting now, with your current equipment.
Do you have any way of measuring the frequency response at your listening position like REW, Omnimic, XTZ, etc? Some simple changes like the sub distance setting in your AVR, position of your mains or main listening location may give a dramatic improvement. So far I think nearfield sub placement is a good start but you need to "see" graphically what's going on to accomplish the above.
Tim
capecodorthopod is offline
post #37 of 43 Old 03-27-2012, 05:11 PM
pokekevin's Avatar
Liked: 102
Originally Posted by SaviorMachine View Post
Tight, punchy bass?
An explosion going off next to you lol
post #38 of 43 Old 03-27-2012, 05:16 PM
Liked: 90
No thanks, I'll leave the boom boom boom to the home theater crowd, who must have low standards because they aim for low frequencies that nobody hears anyway. Tight, punchy bass.
BTW tight, punchy bass.
post #39 of 43 Old 03-27-2012, 05:24 PM
pokekevin's Avatar
Liked: 102
Huh lol
post #40 of 43 Old 03-27-2012, 08:06 PM
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Tim
Was planning on doing something like REW to see what is happening in the room but I haven't got around to that yet. The position of the sofa falls just about in the center of the room which I heard isn't anywhere near ideal but it's the best spot for me to have it, thats why I was thinking of using the MBM since my listening position is pretty much fixed in the room and can't be adjusted at all. My sub placement can be moved quite a bit though.
Subwoofer Xover is set to bypass and on the "1" mark, all speakers are at 80hz and the LFE is subwoofer / 120hz. I use Audyssey MultiEQXT to calibrate everything and it usually sets the subwoofer around the -1.0 db mark.
BB1111 is offline
post #41 of 43 Old 03-27-2012, 09:10 PM - Thread Starter
jsgrise's Avatar
Quoted: 180 Post(s)
Liked: 83
I think the good old sub crawl test would be a good start. LP in the middle is usually not ideal, but sometimes can be good. Give it a try!
jsgrise is offline
post #42 of 43 Old 03-27-2012, 09:39 PM
mojomike's Avatar
Liked: 30
That mid-bass punch has little to do with deep bass, but probably lies somewhere between 50 to 150hz. That's the typical kick-drum range. There are various problems that can lead to less-than-satisfying bass punch.
One possible problem is an excess of deep bass room gain. This causes the deeper bass to overwhelm the punch bass. That may shake the couch, but doesn't give much punch.
Another possible problem is a poor frequency response in the crossover area. For most folks this takes place around 80hz which just happens to sit in the middle of the punch range. Check phase and distance settings as possible causes.
Weak bass performance of the main speakers is another possible problem. Since the main speakers are usually called upon to deliver the upper part of the bass punch, if they are not up to the task, performance here will suffer. Small bookshelf speakers, for example, are most likley not up to delivering their portion of the bass punch spectrum with sufficient power to be realistic.
As others here have suggested, try to measure the frequency response to visualize where the problem lies. As any physician will tell you, you should diagnose the problem before you treat the problem.
In some cases, something like an MBM-12 or perhaps some other small supplimentary sub to enhance the range between 50 and 150hz might be a solution, but again try to understand where the problem comes from before trying to fix it.
mojomike is offline
post #43 of 43 Old 03-28-2012, 07:28 AM - Thread Starter
jsgrise's Avatar
Quoted: 180 Post(s)
Liked: 83
Well said.
jsgrise is offline
