SVS Vs. HSU: who gives the best mid-bass punch? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 43 Old 03-27-2012, 08:41 AM - Thread Starter
jsgrise's Avatar
Quoted: 161 Post(s)
Liked: 57
I read a lot of guys saying that the SVS subs, like the PB13u, are among the best in reproducing high output of ULF and probably a cut above HSU (but more expensive).
But what about the mid-bass chest pounding bass? I know the VTF-15H is very good at it! Are SVS weaker on the mid-bass, equal or better?
DUAL 18" Dayton RSS460HO Custom Build | Sonus Faber Venere 1.5s | Sonus Faber Venere Centre | Sonus Faber Venere Walls | Marantz SR-7010 | Behringer iNuke 6000DSP | Velodyne SMS-1 | JVC D-ILA RS-46 w/ 128" 16:9 1.4 | Custom Bass Traps and Acoustic Panels (11)
jsgrise is offline
post #2 of 43 Old 03-27-2012, 08:44 AM
oztech's Avatar
Liked: 101
I would not say one is better than the other for all their subs it would be on a model versus model for the application you really can't go wrong with either company.
I feel HSU at its price point gives you a little more for your dollar right now.
oztech is offline
post #3 of 43 Old 03-27-2012, 08:46 AM - Thread Starter
jsgrise's Avatar
Quoted: 161 Post(s)
Liked: 57
Let say flagship vs flagship. In other words: 15H vs PB13U
jsgrise is offline
post #4 of 43 Old 03-27-2012, 08:56 AM
oztech's Avatar
Liked: 101
I would say the edge goes to SVS on that one and it should its almost double the price but the 13 is a beast.
oztech is offline
post #5 of 43 Old 03-27-2012, 08:58 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
The 13 Ultra would be superior to a single Hsu 15H. But you can get two VTF15H subs in that price range, and things get a little interesting then On paper two 15H subs should have more midbass, and have almost equal extension. The benefit would be having two subs to smooth out room response.
But you should also look into the JTR Captivator and Seaton Submerssive if you are considering a PB13 Ultra. Will cost you a little more money, but from folks that have have heard and owned these subs, the Seaton and JTR are in a different league.
ack_bk is offline
post #6 of 43 Old 03-27-2012, 09:01 AM
oztech's Avatar
Liked: 101
I agree .
oztech is offline
post #7 of 43 Old 03-27-2012, 09:06 AM - Thread Starter
jsgrise's Avatar
Quoted: 161 Post(s)
Liked: 57
what about the 15H vs the PB12+?
jsgrise is offline
post #8 of 43 Old 03-27-2012, 09:06 AM
gtpsuper24's Avatar
Liked: 99
The room plays a big part in that "midbass kick" Placement and room treatments help greatly.
gtpsuper24 is offline
post #9 of 43 Old 03-27-2012, 09:14 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
PB12+ would be superior to the 15H for both output and extension.
As it should, considering the price difference
I really debated between the PB12+ and the 15H. It was a tough choice and in the end the pocketbook won and I ordered the 15H with the expectation of ordering a second one down the road.
ack_bk is offline
post #10 of 43 Old 03-27-2012, 09:15 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
This is very true.
ack_bk is offline
post #11 of 43 Old 03-27-2012, 09:17 AM
oztech's Avatar
Liked: 101
I can not commit on the PB12+ as I have not had a chance to demo one.
oztech is offline
post #12 of 43 Old 03-27-2012, 09:35 AM
SaviorMachine's Avatar
Liked: 90
Direct comparisons are a little tricky because there are several Hsu subs (such as the VTF-15H, as you can tell, very popular around here) that have no SVSound equivalent, in terms of price, and vice versa.
You can fairly compare the ULS-15 to the SB13-Ultra.
You can fairly compare the VTF3-MK4 to the PB12-NSD.
Every other comparison comes with caveats. SVSound's top-end ported subs are in a different class compared to Hsu's top-end ported subs. So you'll hear "beats it hands-down!" alongside "well it should for X dollars more!"
As I understand it, both manufacturers' subs produce very linear response (each octave is played at about the same loudness as every other octave). For maximum upper- and mid-bass impact, you may want to check out Epik's subwoofers, especially the Empire, which lots of experienced users regard very highly, especially for music.
If you were to ask me, I'd say that the "mid-bass punch" that people sometimes talk about is probably the result of a relatively non-uniform response; otherwise, why would the mid-bass be more prominent than the other frequencies?
Maybe some sealed-sub aficionados can chime in and correct me if I'm wrong about that.
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #13 of 43 Old 03-27-2012, 10:40 AM
capecodorthopod's Avatar
I'll just add that there are some subs that drop off above 80 or so which can leave one wanting for midbass since the LFE channel goes up to 120 (I'm not talking about bass redirected from satellites).
Sometimes room geometry and seating placement create a null in the midbass frequencies that no sub could overcome. Another reason one may sense a lack of midbass could be satellites not able to produce 100-250 hz with authority.
Tim
capecodorthopod is offline
post #14 of 43 Old 03-27-2012, 10:43 AM
gtpsuper24's Avatar
Liked: 99
Large mains will help with the midbass as well. Its a combo, sub, room, mains, anything lacking in either one of those and it might be disappointing.
Multiple subs, corner bass traps, and good large mains.
post #15 of 43 Old 03-27-2012, 11:26 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
If you like mid-bass punch, I would take a close look at the Hsu MBM-12. For mid-bass, that has to be the highest price/performance ratio out there. The Epik Empire has measured fantastically for mid-bass too.
Something said above should be emphasized, mid-bass punch is usually the result of a exaggerated hump or peak at 60 or 70 hz, it does not usually come from a flat FR.
shadyJ is offline
post #16 of 43 Old 03-27-2012, 11:39 AM
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
But if we are watching an action movie shouldn't the gunshots "punch" you in the chest from their mid-bass like I think they do in real life? Is that something that shouldn't happen with a flat FR or is a hump like that something which reflects more accurately to what we would should "feel" from our HT?
I've been considering an MBM-12 myself to fill in that "midbass punch"
BB1111 is offline
post #17 of 43 Old 03-27-2012, 11:44 AM
Liked: 90
Originally Posted by bb1111 View Post
but if we are watching an action movie shouldn't the gunshots "punch" you in the chest... Like they do in real life?
omg no!
:P
post #18 of 43 Old 03-27-2012, 11:55 AM
pokekevin's Avatar
Liked: 102
Originally Posted by Steve1981 View Post
I've shot enough firearms ranging from lowly 22s to 12 gauge shotguns, and I can't recall any of them giving me a punch me in the chest feel... Closest I've come is an M1 Garand in an indoor range. Some of the heavier ones can certainly kick you in the shoulder if you're not holding em right though.
I know how you feel
pokekevin is offline
post #19 of 43 Old 03-27-2012, 12:25 PM
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
I've shot enough firearms ranging from lowly 22s to 12 gauge shotguns, and I can't recall any of them giving me a punch me in the chest feel... Closest I've heard was an M1 Garand in an indoor range. Some of the heavier ones can certainly kick you in the shoulder if you're not holding em right though.
What does it feel like when a grenade or explosion goes off? I'm just trying to find what gives you that "punch" in real-life that would be missing in HT.
BB1111 is offline
post #20 of 43 Old 03-27-2012, 12:30 PM
oztech's Avatar
Liked: 101
Originally Posted by BB1111 View Post
I'm starting to not see the point of "mid-bass punch" then...
There are other things like explosions and close miked train wrecks that give you that tactical feel but gun fire realistically will not unless its overly synthesized and I left out earthquakes they have mid to ultra low tactical feel.
oztech is offline
post #21 of 43 Old 03-27-2012, 12:34 PM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
It's cool if/when you can get it.
There are other things like explosions and close miked train wrecks that give you that tactical feel ...
A school of piranha swimming by also provides a suprising amount of tactile sensation. I never imagined there'd be so much LFE under water, but it was in a movie, so it must be true.
eljaycanuck is offline
post #22 of 43 Old 03-27-2012, 12:45 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
I just have my buddy punch me in the chest during a movie explosion.
xero112 likes this.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
post #23 of 43 Old 03-27-2012, 12:57 PM
shadyJ's Avatar
Liked: 1350
Firearms discharge in real life is a high frequency burst, there is not much bass there. In movies and games, they are just mixed to sound like they have bass. By the way, you would not want to have your home theater playback firearms discharge at realistic levels in realistic frequencies, that would damage your hearing.
Having a system with a perfectly flat frequency response is still not going to sound 'real', you have to have the dynamic response and low-distortion output capability to back it up, and you also have to have recordings that are mixed and mastered realistically. I would go after what sounds 'good', and that isn't necessarily is going to be what is accurate.
shadyJ is offline
post #24 of 43 Old 03-27-2012, 01:00 PM
sputter1's Avatar
Liked: 42
I'm sure it would be a 'once in a lifetime' experience.
sputter1 is offline
post #25 of 43 Old 03-27-2012, 01:02 PM
shadyJ's Avatar
Liked: 1350
That would be cheaper.
That depends on how hard he hits you. A cracked rib will be more expensive than any of the subs mentioned here. It's still worth it though, the buddy-chest-punch is one of the immersive home theater experiences I've yet experienced. The tactile feel is spectacular!
shadyJ is offline
post #26 of 43 Old 03-27-2012, 01:15 PM
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Can't say that I've gone out of my way to find out
A kickdrum at 1 meter?
Just on the fence about buying this MBM-12. Trying to get some opinions on how much it'll really add to the experience
BB1111 is offline
post #27 of 43 Old 03-27-2012, 01:20 PM
kwarny's Avatar
Drivers produce acoustic energy. Once someone finds out how to make the sound wave travel faster than a sound wave then we may be able to experience the shock wave haha.
The greatest enemy of knowledge is not ignorance, it is the illusion of knowledge - Stephen Hawking
Kyle Bosso - SOB
kwarny is offline
post #28 of 43 Old 03-27-2012, 01:43 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Haha, nice one..
ack_bk is offline
post #29 of 43 Old 03-27-2012, 02:01 PM
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Depends; what do you have now in terms of speakers/subwoofer?
Everything sounds fantastic except for it missing that hard "punch in the chest", I get only a "gentle punch in the chest"
BB1111 is offline
post #30 of 43 Old 03-27-2012, 02:29 PM - Thread Starter
jsgrise's Avatar
Quoted: 161 Post(s)
Liked: 57
Right now I have Rti A5 / Rti a6 (Center) / Rti A1 as heights and Fxi A4 as surrounds. LFM-1 Plus for my subwoofer in a 2300 cu ft room.
Is your LFM-1 nearfield or farfield?
jsgrise is offline
