Settings For Outlaw LFM-1 EX Sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 04-04-2012, 09:48 AM - Thread Starter
agrandal's Avatar
Hello. Needed some help to set up my new Outlaw LFM 1 EX sub. I have it in a fairly large room and it sounds pretty good, however I am not getting that rumble feel during great action movies.
My question is should I set it to Max output or max extension? Also I left the port plugged that cam with it. Should I take that out? I am not looking for the bass to be super loud, however I would like to be able to feel the bass.
Please let me know what suggestions I can make for settings. Thanks.
Fred
agrandal is offline
post #2 of 24 Old 04-04-2012, 10:04 AM
eljaycanuck's Avatar
Quoted: 1344 Post(s)
Liked: 1958
According to pg. 8 of the owner's manual (PDF):
- with one port plugged, use the Bass Extension mode;
- with both ports open, use the Max Output mode.
(Do not use the Bass Extension mode with both ports open.)
Try each one in turn, being sure to re-calibrate your system each time, and go with the one that sounds best to you.
eljaycanuck is offline
post #3 of 24 Old 04-04-2012, 10:16 AM - Thread Starter
agrandal's Avatar
Great. Thanks.
Does one mode provide louder bass and the other provide lower bass? What does the porting do? If I want more rumble should I go with max extension? Thanks.
agrandal is offline
post #4 of 24 Old 04-04-2012, 10:19 AM
Liked: 1958
Yup. Max Output lets the sub play louder while not digging quite as deep. Bass Extension lets the sub dig deeper while not playing quite as loud (although it should still play pretty loud).
The ports determine the tuning frequency.
post #5 of 24 Old 04-04-2012, 10:21 AM - Thread Starter
agrandal's Avatar
Great. i have it plugged in Bass Extension now. It is loud enough but I feel it is lacking the deep "feel" bass. I will try max output and see if that changes to what I am looking for better.
Thanks for the info.
agrandal is offline
post #6 of 24 Old 04-04-2012, 10:22 AM
flickhtguru's Avatar
Liked: 111
Max extension will not be as loud but will go down to 16hz -2db. Max output will be louder but will only go down to 22hz -2db.
I have 2 Pluses and both of them are in max extension.
Also be sure to read your manual. If you have the switch in the wrong position compared to if your port is plugged or not you could damage your sub. Port plugged switch MUST be at Max Extension. Port unplugged switch MUST be at Max Output.
The porting is what tunes the sub to be able to hit certain low frequencies. Like max extension mode will hit 16hz -2db but the port is tuned for 18hz. This means that around the 17 - 19 hz range there will be air and sound coming from the port. But lets say at 40 hz or any other number the sub will pretty much act as if its sealed and nothing really comes out of the port.
Shawn
flickhtguru is offline
post #7 of 24 Old 04-04-2012, 10:24 AM
Liked: 1958
Glad to help.
post #8 of 24 Old 04-04-2012, 10:29 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
If you have a large room you will probably need to go with max output to fill the room better. Sub location and room size are huge determining factors.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #9 of 24 Old 04-04-2012, 02:52 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
But MO mode won't necessarily give you any more volume if the sub is configured correctly, because the output should be level matched either way by your room correction software on your receiver. The advantage of MO mode is if your room is so big that your sub is challenged--reaching its limits--the MO mode will let it get a little louder before reaching those limits. In fact, with MO mode, you might feel less because your sub will no longer be producing some of those lower frequencies enough to benefit from them--you've shortened the frequency range.
So how big is your room in cubic feet (volume)? How far away are you seated? That can tell us a little more. I would bet other factors are a problem. For instance placement in the room or the way you have it configured otherwise.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #10 of 24 Old 04-04-2012, 02:56 PM
pokekevin's Avatar
Quoted: 12 Post(s)
Liked: 102
Great. Thanks.
if you want the punch than that's around 50 to 60hz. Room rumbles is around the 20s.
All in all set it to what you like
I personally use me mode but also have an mbm for mid bass
pokekevin is offline
post #11 of 24 Old 04-04-2012, 03:08 PM
spyboy's Avatar
Liked: 48
You might try nearfield placement. That means placing the sub within 4 feet of the listening position.
spyboy is offline
post #12 of 24 Old 04-07-2012, 05:34 AM - Thread Starter
agrandal's Avatar
The room is 15 x 20 with vaulted ceilings of 18 at the highest point and about 8 at the lowest point. The sub is about 8 or 9 feet from the main listening area
agrandal is offline
post #13 of 24 Old 04-07-2012, 06:51 AM
chashint's Avatar
Liked: 54
chashint is offline
post #14 of 24 Old 04-07-2012, 08:36 AM
hometheatergeek's Avatar
Quoted: 41 Post(s)
Liked: 44
For that size room, which I suspect is open to other areas, that one sub will not come close to what you are seeking. Like Spyboy said best you can do is move it nearfield.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #15 of 24 Old 04-07-2012, 09:38 AM
Quoted: 978 Post(s)
Liked: 506
Or get a second sub.
post #16 of 24 Old 04-07-2012, 09:43 AM
Quoted: 41 Post(s)
Liked: 44
Or a Quad system like mine?
Hometheatergeek
aka AL
My Current System
post #17 of 24 Old 04-07-2012, 09:44 AM
spyboy's Avatar
Liked: 48
Before spending any more money the OP should try nearfield placement, the cost of which is zero. The OP said the sub was 8-9 feet from the main listenging area. If he puts the sub really close that might solve his problem. And if not a second sub may be in the budget.
spyboy is offline
post #18 of 24 Old 04-07-2012, 09:55 AM
Quoted: 41 Post(s)
Liked: 44
You noticed I never said anything about additional subs in my OP. I could not help myself after that last post.
Hometheatergeek
aka AL
My Current System
post #19 of 24 Old 04-07-2012, 12:02 PM
cel4145's Avatar
Liked: 3001
Agreed. There also may be other placement options that will work. The EX was rated by Audioholics in rooms up to 5,000 cubic feet. Granted each room is different, but it works in mine that is a 6,000 with some good rumble and bass effects. It doesn't pressurize my room, but I can definitely feel it from 11 ft away.
cel4145 is offline
post #20 of 24 Old 04-07-2012, 12:59 PM
JChin's Avatar
Quoted: 367 Post(s)
Liked: 210
Hi agrandal, what receiver do you have and what are the settings? Depend on model of your receiver, did you run auto setup? Are the front speakers set to Large or Full? What's the reciever subwoofer trim level set at?
JChin is offline
post #21 of 24 Old 04-07-2012, 06:06 PM
Quoted: 978 Post(s)
Liked: 506
I want two more but the boss shut that idea down.
post #22 of 24 Old 04-08-2012, 06:52 PM - Thread Starter
agrandal's Avatar
I am using the Denon 2112. My volume settings on the sub are 12 o clock position. i did run audyssey XT but the sub came back with a setting of like minus 12, so I adjusted it a bit higher on the receiver settings as it barely sounded.
agrandal is offline
post #23 of 24 Old 04-08-2012, 06:58 PM
JChin's Avatar
Quoted: 367 Post(s)
Liked: 210
Turn the subwoofer volume knob down to about 2.5 or 3 (NOT clock position) and rerun auto setup to get sub trim closer toward "0" (-3). Then after adjust receiver sub channel trim if needed.
JChin is offline
post #24 of 24 Old 04-08-2012, 09:45 PM
cel4145's Avatar
Liked: 3001
+1
Many Outlaw owners have found that this technique greatly improves the sound of the sub. Even if you think the gain (volume) on the back of the sub seems really low, ignore that and shoot for the -3db to 0db result from Audyssey. This best optimizes the gain on the sub for the input from the receiver.
Then once that is achieved, trying bumping up the sub channel level on the receiver 2db or 3db if you need a little more bass, but don't change the gain on the sub.
cel4145 is offline
