What's better ported or sealed subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 46 Old 04-12-2012, 10:00 PM - Thread Starter
asere's Avatar
Quoted: 1373 Post(s)
Liked: 260
I was told sealed sound much smoother. I am looking at filling the room but at the same time not shake the house.
asere is offline
post #2 of 46 Old 04-12-2012, 10:07 PM
pokekevin's Avatar
Liked: 102
Ported subs might be better to fill your room since they can play louder. What is your room size?
pokekevin is offline
post #3 of 46 Old 04-12-2012, 10:14 PM - Thread Starter
asere's Avatar
Liked: 260
Room size is 5400 cubic feet
asere is offline
post #4 of 46 Old 04-12-2012, 10:24 PM
oztech's Avatar
Liked: 101
Might want to read the sub shoot out threads as to the fact when subs are done right they guessed wrong if it was sealed vs ported. Myself it is hard to guess but the fact a ported sub will fill the room easier makes it an easy decision for me.
oztech is offline
post #5 of 46 Old 04-13-2012, 05:55 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
sealed dont have as much rolloff after 20Hz or so, but Ported will have more output down to their tuning point (which can be down to 16Hz)
Brian Fineberg is offline
post #6 of 46 Old 04-13-2012, 08:27 AM
desertdome's Avatar
Quoted: 1119 Post(s)
Liked: 1219
This generalization is true for subs with similar displacement and amplifier power. When you compare subs with different displacement and amps it is no longer necessarily true. For example, the sealed Epik Empire has more output at all frequencies than the ported Outlaw Audio LMF-1 EX when it is in its lowest tune (1 port open). With both ports open, the Outlaw only has the advantage at around 25-31.5 Hz. The greater displacement of the Empire from having two 15" drivers gives it the advantage even though both subs are almost identical in size.
High Impact AV
desertdome is online now
post #7 of 46 Old 04-13-2012, 09:09 AM
Liked: 3514
Thanks for the clarification i should have mentioned that
post #8 of 46 Old 04-13-2012, 10:00 AM
spyboy's Avatar
Liked: 47
How much is your budget?
spyboy is offline
post #9 of 46 Old 04-13-2012, 01:25 PM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
THat's a good question for the search engine. Using advance search, title search only and "ported" as my search word, dozens of previous threads came up asking the same question. Here's a recent poll:
http://www.avsforum.com/avs-vb/showt...ghlight=ported
You'll find the other existing threads using the directions above. The search engine is the quickest way to finding information at AVS. I highly recommend it.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
post #10 of 46 Old 04-13-2012, 07:36 PM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
^^^^^^ +1
I like sealed alignments. I'm able to shape the response with little regard to the tune. Enclosure volume can assist in limiting over excursion. Trade off time... You better have alot of stroke in that driver, and alot of power, especially if you plan on extending down into single digits.... And speaking of single digits, it wont be done with one driver unless you bolt it to the side of your head Lol. Multiples are a must to create the feel of limitless bass and multiples also smooth out room modes at the LP.....and to get the SPL high enough at the LP.
So, with that said i will go back to watching Rush Time Machine Tour on BR......peace KG
.....errr and my six sealed subs bahahaha
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #11 of 46 Old 04-14-2012, 03:03 AM
adio's Avatar
question for everyone on here........ why don't more people build a ported sub with round ports and then just plug them to see which sound they prefer?
adio is offline
post #12 of 46 Old 04-14-2012, 05:18 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
SVS has been doing that for years, i believe there is a little EQ magic in there as you have to activate some cicuitry as changes are made.
I look at it like tires on a car. Trade offs are all over the place, sticky tires for cornering wont last as long as a nice hard touring tire, they both get you to work, just a little differently....
I chose sealed at first for the ease of the build. Once i really started to take advantage of the benefits i made them my default alignment.
You can get your steak rare or well done, either way its a cut of beef...
I always find it interesting to revisit the benefits of both as long as we keep civil, sometimes boys will be boys...
Ok ported boys chime in LOL
post #13 of 46 Old 04-14-2012, 06:51 AM
mojomike's Avatar
Liked: 30
I choose ported subs because it simply is the better way to get the job done in my particular room. If it went with sealed, it would take at least twice as many subs with at least four times as much power and obviously considerably more cost just to get similar output levels down to 13 or 14 hz. Again, that's in my particular room. In a different type of room, everything might be different about my sub choices.
mojomike is offline
post #14 of 46 Old 04-14-2012, 06:54 AM
Archaea's Avatar
Quoted: 2837 Post(s)
Liked: 2416
I personally and subjectively have experienced no, as in zero, magic below about 16hz.
With all the subs I've heard in the three meets I've attended - as long as the ported sub is solid to 16 hz or 18hz or so(the limit of my hearing with test tones) I can't tell a difference in those "missing lower frequencies". As to tactile feeling in th subsonic frequencies I think its placebo in any real world material outside of test tones, to reach the spl levels you'd need to feel those subsonic frequencies you'd be beaten to death by the frequencies you can hear --- at least in any real world program material.
This is my opinion and experience. Others may have different opinions. We can choose to disagree based on our individual hearing capability and experiences. For my part I've heard multiples of identical sealed drivers and it still didn't make any magic in the frequencies below audible for real world program material like black hawk down, war of the worlds, hulk, etc.
I would also point to the fact in controlled blind testing at our recent subwoofer meet nobody else could either of nine voters.
IMO, a good ported sub is every bit as good as a good sealed sub. It just takes less of a good ported sub to reach a spl goal assuming similar driver capacities are used.
I've felt in previous sighted tests that sealed does slightly better for music and a good ported sub is slightly better for movies but after the 2012 blind sub meet linked in my signature, all bets are off.
kilobulb likes this.
Archaea is online now
post #15 of 46 Old 04-14-2012, 07:15 AM
oztech's Avatar
Liked: 101
I guess it just depends on the sub design and keep in mind there are plenty of high end main speakers that are ported that are great with music where tight bass is essential.
oztech is offline
post #16 of 46 Old 04-14-2012, 08:53 AM
eiger's Avatar
Quoted: 12 Post(s)
I have dual A7s-450s and they are sealed and have no difficulty filling the room with low, tight bass for movies and music.
Could probably have achieved same with one of them, but of course why be happy with one? ;-)
eiger is offline
post #17 of 46 Old 04-14-2012, 09:17 AM
joehonest's Avatar
Quoted: 90 Post(s)
Liked: 37
There is nothing worse than a movie playing just a low rumble and you hear the port noise from a cheap sub, even if it cost $1200..
joehonest is offline
post #18 of 46 Old 04-14-2012, 01:45 PM
oztech's Avatar
Liked: 101
Same can be said for sealed when its overdriven no port noise just the mechanical noise of the driver bottoming out.
oztech is offline
post #19 of 46 Old 04-14-2012, 11:47 PM
avspace's Avatar
Now I'm going to be speaking in generalizations, but I think the vibe is that sealed is better for musicality and ported is better for generating more output.
I tried sealed and I did find it to have great musicality. But for movies it just didn't have enough output, so I went with ported. It's a trade off between the two. Of course, you have many exceptions to the rule, like people using variable tuning modes in their HSU subs to jump between sealed and ported modes, the best of both worlds.
Then you have subs like the HSU ULS15, which is an monster sealed sub that has strong output. The Epik subs also have tons of output as well for sealed subs too, which makes them exceptions to the generalization.
I suppose you really have to ask yourself what kind of sub do you need for your particular space and set a budget.
avspace is offline
post #20 of 46 Old 04-15-2012, 06:39 AM
Archaea's Avatar
Liked: 2416
The subs you defined as monsters I would not.
It takes about two uls-15s to equal a vtf-15h and I wouldn't define the vtf-15h as a "monster". A great sub yes! A monster of output? No.
Epik Empire - same thing.
Both good subs and great choices for ~ a grand, but not monsters I'd you are willing to spend more money or DIY there are certainly monster sealed options.
post #21 of 46 Old 04-15-2012, 07:13 AM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
It all depends on the goals. Ported are great to their tune and slightly below in room but if you want more output lower than the tune then you need sealed or some monster ported subs. All sealed subs need need a boost down low, whether a shelving filter or LT circuit and if you compare a sealed VS ported without one the ported will always seem better for movies. Of course this assumes both subs are equal in the first place with the only the alignment being different.
Marantz 7702 Atmos
MKtheater is online now
post #22 of 46 Old 04-15-2012, 07:35 AM
mojomike's Avatar
Liked: 30
I'm sure those ULS15's are excellent subs, but the formula of a compact sealed sub powered with only 500 watts does not make for a lot of output. That's why they are frequently sold as dual packs and quad packs.
mojomike is offline
post #23 of 46 Old 04-15-2012, 07:36 AM
SaviorMachine's Avatar
Liked: 90
This is extremely interesting, everything you're saying here.
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #24 of 46 Old 04-15-2012, 07:44 AM
adio's Avatar
good analogies........ but i'm talking for the DIY world. idk why more regular ppl don't give it a shot.......
adio is offline
post #25 of 46 Old 04-15-2012, 07:47 AM
adio's Avatar
the only monster sealed sub i can think of has an 18" (or now a 21") sub and at least 1000 watts minimum. what makes a monster DIY sealed to you?
adio is offline
post #26 of 46 Old 04-15-2012, 08:18 AM
Sick Mother's Avatar
Another (and great) monster sealed sub is the Seaton SubMersive HP. Dual 15"s with a 2400w amp. Just an incredible sub, albeit at a higher price than most.
Sick Mother is offline
post #27 of 46 Old 04-15-2012, 08:42 AM
Archaea's Avatar
Liked: 2416
Put a "monster" lms-5400 driver in a sealed cabinet (like I heard this weekend) up against the uls or empire and you'll know exactly what I mean. The lms-5400 was very impressive even powered by a ep4000 amp. The Seaton Submersive HP I would consider a monster sealed offering as well. I've heard all of theses subs mentioned on multiple occasions except the uls15 which I have not heard at all.
post #28 of 46 Old 04-15-2012, 09:40 AM
carp's Avatar
Quoted: 2485 Post(s)
Liked: 1741
Where did you hear that? Was it at the speaker GTG? Lucky bast*rd, I'd love to hear a lms-5400. Detailed impressions?
carp is offline
post #29 of 46 Old 04-15-2012, 10:29 AM
MKtheater's Avatar
Liked: 1116
EP-4000 won't do it justice BUT it should still be great. I just watched a few demos without my EQ boost down low and without it my DTS-10's were much better down low! Add in that low end boost the sealed is just as good! Of course you need lots of displacement to accept this boost.
I am with Carp here, Archaea how was it?
Marantz 7702 Atmos
post #30 of 46 Old 04-15-2012, 10:30 AM
Archaea's Avatar
Liked: 2416
Yes at the wisconsin speaker meet this weekend. Ill probably write a little something up.
;p
