Subwoofer 2.5 feet from floor? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-13-2012, 10:13 PM - Thread Starter
punman's Avatar
Due to space constraints, could a subwoofer be placed on a 2.5 foot high end table (not a shelf) without negative consequences, or do they need to be on the floor for best effects?
punman is offline
post #2 of 9 Old 04-13-2012, 10:25 PM
Archaea's Avatar
Quoted: 2897 Post(s)
Liked: 2494
Might end up better on table. Depends completely how it interacts with your room.
Archaea is online now
post #3 of 9 Old 04-14-2012, 07:44 AM - Thread Starter
punman's Avatar
I should also add that this is a downward firing sub and there is carpeting on the floor.
punman is offline
post #4 of 9 Old 04-14-2012, 09:11 AM
kevinzoe's Avatar
Hi Punman,
I have one of my subs elevated to 4 feet to effectively reduce a height induced bass null and it's works very well. Mine is fwd firing however.
How many subs do you have? Do you have an acoustical measurement tool to see what your ears are hearing?
If you have only one sub then you will get more room gain by placing it on the floor next to a wall or corner. If room gain isn't an issue then I suspect the table location will work but tools to measure it are kinda important.
kevinzoe is offline
post #5 of 9 Old 04-14-2012, 11:37 AM - Thread Starter
punman's Avatar
Just the one sub. I use Audyssey for set-up.
I have room in corner near the Receiver but I thought corner placement for subs somehow was not ideal. I could do floor in the corner.
punman is offline
post #6 of 9 Old 04-14-2012, 11:46 AM
sivadselim's Avatar
Quoted: 163 Post(s)
Liked: 154
Originally Posted by punman View Post
.........could a subwoofer be placed on a 2.5 foot high end table (not a shelf) without negative consequences...............
As long as it is stable and doesn't move itself around when in use, it should be fine.
I should also add that this is a downward firing sub..........
Should still be fine.
..........and there is carpeting on the floor.
No problem. Although carpeting might have some affect on the upper range of frequencies that a sub produces, it's going to be there no matter where you place the sub or how its driver is oriented. Essentially, irrelevant.
...........but I thought corner placement for subs somehow was not ideal.
It depends. It can be a good thing, or it can be a bad thing. Depends upon how the sub interacts with the room when placed there. What version of Audyssey does your AVR have?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #7 of 9 Old 04-14-2012, 11:47 AM
Luis Gabriel Gerena's Avatar
Quoted: 94 Post(s)
Liked: 63
Nothing wrong with corner placement in my opinion but nothing beats testing/measuring and like someone said, moving it from the floor can actually be better depending on your room. Like on mine , the 40hz gets improved when I moved from my listening position to a bit higher one..at least my ears
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
post #8 of 9 Old 04-16-2012, 04:14 PM - Thread Starter
punman's Avatar
I am trying it on the elevated stand. For the few minutes I have listened, I think it may be as good as on the floor.
punman is offline
post #9 of 9 Old 04-17-2012, 05:52 PM
citizen arcane's Avatar
Quoted: 290 Post(s)
Liked: 8625
Theoretical Foundation Behind Risers
http://forum.blu-ray.com/showpost.ph...75&postcount=2
I prefer mine to be risen for aesthetics as well as changing the room boundaries:
I have OC 703 under the tables as well.
¿lɐɯɹou ǝq ʎɥʍ
citizen arcane is offline
