Hooking up 4 Subwoofers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 56 Old 04-14-2012, 11:22 AM - Thread Starter
wingnut4772's Avatar
Liked: 29
Want to hook up 4 Hsu Uls15 subwoofers 2 stacked on either side of the front stage where I already have 1 subwoofer cable in each spot. My issue is that I can't add a new cable as they are in wall ( or it least it would be a PITA). The obvious solution is a Y connector but I cant find any that are long enough to reach each input from one sub to the other. . Also, I can't seem to find any Y connectors that are all female. Am I missing something obvious ?
TIA
Kaboom.
wingnut4772 is offline
post #2 of 56 Old 04-14-2012, 11:47 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
yes you are..... go to radio shack or best buy or some where and get the female y splitter. They are not long so you will have to get rca or coax cable as well. If you dont want to run a long cable, think about getting a wireless transmitter/receiver for your application.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #3 of 56 Old 04-14-2012, 11:49 AM
Quoted: 978 Post(s)
Liked: 506
Also this might help you on sub placement.
http://www.harman.com/EN-US/OurCompa...s/multsubs.pdf
post #4 of 56 Old 04-14-2012, 11:51 AM - Thread Starter
Liked: 29
Thanks but I would need an all female y splitter and for the life of me I can't find one.
And I have no interest in using the wireless feature as I've used it in the past with not the best results.
Kaboom.
post #5 of 56 Old 04-14-2012, 01:04 PM
hometheatergeek's Avatar
Quoted: 41 Post(s)
Liked: 44
Hey bud you can do it real easy. You have a male RCA going into the first sub so disconnect it and plug it into a short 2 female one male Y.
Plug the RCA from the wall into one of the females. Plug the male part of the Y into the top sub then run a short male to male RCA from the other female part of the Y to the second sub on the bottom.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #6 of 56 Old 04-14-2012, 01:25 PM
henrich3's Avatar
Quoted: 576 Post(s)
Liked: 497
henrich3 is online now
post #7 of 56 Old 04-14-2012, 01:43 PM - Thread Starter
Liked: 29
Holy cow I feel stupid. It was obvious! Thanks. For some reason I didn't think it would work that way. I thought the source signal had to be from the single end. I guess I was over thinking it.
Kaboom.
post #8 of 56 Old 04-14-2012, 01:48 PM
Quoted: 41 Post(s)
Liked: 44
I'm here for family anytime. Let me know how the subs sound stacked.
Hometheatergeek
aka AL
My Current System
post #9 of 56 Old 04-14-2012, 02:48 PM
sivadselim's Avatar
Quoted: 260 Post(s)
Liked: 221
BTW, there are cheap adapters that will convert the ends of any Y-adapter to whatever you might need.
convert a male end to a female end:
http://www.cablesforless.com/RCA-Cou...ale-P4949.aspx
convert a female end to a male end:
http://www.cablesforless.com/RCA-Cou...-P4948C84.aspx
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #10 of 56 Old 04-14-2012, 02:53 PM
Roger Dressler's Avatar
Quoted: 1764 Post(s)
Liked: 902
Could use the wireless feature. Set all the subs to receive the same transmitter.
Deadwood II Theater
Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is online now
post #11 of 56 Old 04-14-2012, 02:54 PM - Thread Starter
Liked: 29
Thanks for all the replies. I guess I was really just hooked on the Y adapters being directional or something like that. My problem is solved. I knew it was a blonde oversight.
I really don't like the wireless feature on the subs. I never could use it successfully without popping or signal interference.
Kaboom.
post #12 of 56 Old 04-14-2012, 03:30 PM
kevinzoe's Avatar
Convert a male end to a female end. . . . Sounds like my neighbor Bonnie who used to be Ronnie . . .
kevinzoe is offline
post #13 of 56 Old 04-14-2012, 04:36 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
hey wingnut, have you considered stacking them all up in a line array? The Dr had some interesting things to say about the performance of that kind of arrangement, it has me curious. If I had more ULS's I would try it out myself.
shadyJ is offline
post #14 of 56 Old 04-14-2012, 05:05 PM - Thread Starter
Liked: 29
Not really. Mostly for aesthetic reasons but also because I like the improved response from placing them in separate positions.
Kaboom.
post #15 of 56 Old 04-14-2012, 05:22 PM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
If you like the "improved response from placing them in separate positions", consider placing all 4 in separate positions:
Midwall of each of the 4 walls (Welti)
1 in each corner (Welti)
Random Placement, (Geddes)
At the very least, measure the placements and optimize the measurements.
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #16 of 56 Old 04-14-2012, 05:28 PM - Thread Starter
Liked: 29
Craig
Again aesthetics. And I like them stacked more than I like them in 4 different spots. I've tried them every which way. I had them stacked before but with 4 cables.
Kaboom.
post #17 of 56 Old 04-20-2012, 07:01 PM - Thread Starter
Liked: 29
Ok. I'm revisiting wireless. ( sigh)
Kaboom.
post #18 of 56 Old 04-21-2012, 06:37 AM - Thread Starter
Liked: 29
Craig
I have them spread out right now. 2 in the corners on the left and 2 on the right, where corners would be if there were a wall. This configuration cured my 40 hz null but I am gonna see if I have any issues with the wireless and if I like the way it looks. Sounds pretty good so far. It turned out they didn't look so great stacked and since this isn't a dedicated room, looks are important to me. ( I'm a chick - so of course ! Ha)
Kaboom.
post #19 of 56 Old 04-21-2012, 11:02 AM
Quoted: 41 Post(s)
Liked: 44
Wow you learn something everyday. Do you have a way to run a sub wire under the room the subs are in? That is what I did. One is 25 feet the other one is 30 feet and I have no issue with signal loss. Conversely you could go up and over with cabling too. Just a thought.
Hometheatergeek
aka AL
My Current System
post #20 of 56 Old 04-21-2012, 11:06 AM - Thread Starter
Liked: 29
I could. I have all my stuff wired to a closet anyway so there is no gear out in the room. It would just be a royal PITA to do it, especially since that is an exterior, concrete wall. I'll digest it for awhile and see if I even like the placement.
Edit: not under but through the attic.
Kaboom.
post #21 of 56 Old 04-21-2012, 12:07 PM
bsoko2's Avatar
Quoted: 75 Post(s)
Liked: 79
Try 2 to the front in the L & R corners and the other 2 to the left and right of the seat (preferably against the wall). My 3 Submersives are one midwall to the front and 2 L & R to the wall at the seat.
bsoko2 is offline
post #22 of 56 Old 04-21-2012, 02:23 PM - Thread Starter
Liked: 29
I only have left corners. Front and rear. The right side opens up to the house.
Kaboom.
post #23 of 56 Old 04-23-2012, 06:23 AM - Thread Starter
Liked: 29
After contrasting and comparing I have decided to go ahead and hardware the 2 in the rear. Wireless is adequate but the bass is tighter wired. Overall pretty happy with the response coupled with the SMS1.
Kaboom.
post #24 of 56 Old 04-23-2012, 06:49 AM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
With 4 subwoofers, setting them up is critical. How are you setting levels? How are you calibrating the system? Do you have any room correction/EQ? Do you have any measuring equipment?
Craig
Lombardi said it:
My System
post #25 of 56 Old 04-23-2012, 07:20 AM
ccotenj's Avatar
Liked: 101
rather interesting observation there...
- chris
ccotenj is offline
post #26 of 56 Old 04-23-2012, 07:23 AM - Thread Starter
Liked: 29
Craig
I have an SMS1 and an SPL meter. I have them all set equally from my listening position at the same db. Like I said, my room opens up to the right so the 2 on the left are in corners and the two on the right are in the place where corners would be if there were a wall. They re all symmetrical and really the only places I can put 4 subs without stacking them in the front. I have a fireplace to my left in the middle and french doors to the rear in the middle.
Kaboom.
post #27 of 56 Old 04-23-2012, 07:34 AM - Thread Starter
Liked: 29
Here are some pics. I am open to suggestions....
Kaboom.
post #28 of 56 Old 04-23-2012, 08:25 AM - Thread Starter
Liked: 29
It seems that way to my ears.
Kaboom.
post #29 of 56 Old 04-23-2012, 08:33 AM
JackOften's Avatar
Quoted: 14 Post(s)
I've measured a couple db's drop using wireless vs. wired (same subwoofer and avr settings)... Might be what you are hearing differently, but with that being said I'd never argue that your "tightness" observation is incorrect since you may have a better ear than me.
JackOften is offline
post #30 of 56 Old 04-23-2012, 08:36 AM - Thread Starter
Liked: 29
That's true but I have calibrated for the disparity. My guess is timing or I could be imagining it but I don't think so. I do have pretty discerning ears lol.
Kaboom.
