Please advice on subwoofer. - AVS | Home Theater Discussions And Reviews
Old 04-24-2012, 04:22 AM - Thread Starter
lipricci's Avatar
Hi,
I'd appreciate any advice on which subwoofer I should buy.
Price: max US$ 800;
Room dimensions: 18 feet x 11.5 feet. Roof is 7.2 feet tall. Room is open on the left (kitchen attached like "T" format);
Uses: 40% movies / 30% regular TV / 20% gamming / 10% music;
Timeframe: I need it before may 15th (my brother will be in NY and will bring it to me here in Brazil).
I already have a NR-809 (onkyo) Receiver and plan to buy a CSi A4 Center speaker and a RTi A7 floorstanding.
Thank you very much.
Felipe Ricci
lipricci is offline
Old 04-24-2012, 04:53 AM
flickhtguru's Avatar
Liked: 105
What do you mean max size 10"? The woofer driver itself? The width? height? or depth? of the cabinet?
Why this limitation?
Shawn
flickhtguru is offline
Old 04-24-2012, 05:06 AM - Thread Starter
lipricci's Avatar
I'm thinking 10" woofer max because it's going to be placed under a rack that is 15.7" height.
I should said that rather than limiting the woofer, right? Sorry for that.
lipricci is offline
Old 04-24-2012, 07:51 AM
Liked: 105
FYI you are limiting yourself very much by your size constraint. Also usually under things is not the optimal place for subs. The sub crawl is the best way to determine where to place them.
With that said if you can't move it anywhere else and you need that size. I would recommend the SVS SB12-NSD. http://www.svsound.com/subwoofers/sealed-box/sb12-nsd
Shawn
Old 04-24-2012, 10:45 AM - Thread Starter
lipricci's Avatar
Thank you for the quick response! I'll take a look at it.
this limitation is imposed by my wife. If I want a home treater in the living room, it has to be harmonic with the furniture. during use I'll probably place it somewhere else and put it back when not using.
what about the supercube the 4000? Is it a recommended option?
Thanx
lipricci is offline
Old 04-24-2012, 10:55 AM
Liked: 105
Never heard it be most ppl say that Def Tech really exaggerates their specs on their subs. SVS would definitely be a better choice.
Shawn
Old 04-24-2012, 03:45 PM
Kini62's Avatar
Quoted: 559 Post(s)
Liked: 564
The NHT 12 will fit in that space as well. Supposed to be pretty good.
http://www.nhthifi.com/Subwoofer-hom...&category=3779
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Old 04-25-2012, 06:44 AM
eaamon's Avatar
Quoted: 42 Post(s)
Thanx
harmonic furniture huh? from the DIY pages
check this out and have one made to match your furniture. hidden in plain site.
http://www.avsforum.com/avs-vb/showthread.php?t=1340095
just a thought, even if you hired it our to a cabinet builder you would end up with some thing real!
and you would not have to hide it after use...
my HT
eaamon is offline
Old 04-25-2012, 07:47 PM - Thread Starter
lipricci's Avatar
That's a great job!
But my expertise in DIY is pretty much none. Also, the furniture is already there, so I'm the one who have to adapt to the living as it is.
I'll buy the SB12-NSD, following the recomendation here and on other threads. It seems to fit great on my needs.
I'm just having trouble to order it.
My credit card is been refused with a wrong billing address error despite my address been correct on the account info. Maybe because my card is from Brazil and the delivery is set to NY. I'll contact them to solve this problem.
lipricci is offline
