Saint-Saëns: Symphony No. 3 "Organ" - AVS Forum | Home Theater Discussions And Reviews
Old 04-24-2012, 11:16 PM - Thread Starter
intoflatlines's Avatar
I picked up a CD that includes Saint-Saëns: Symphony No. 3 "Organ" and I'm curious.. I always thought that the final movement was supposed to have the deepest organ notes. Previously, I have only listened to the final movement, and have only done so with very lossy audio formats, but it certainly was earth shaking. However, on the CD I got, the deepest bass seems to be in the "Poco Adagio" portion, which I think is either the second movement or the last half of the first movement (sorry, I don't know much about classical music or how the different parts are distinguished/named). Parts of this movement shook my room more than anything has before. My questions are:
- What part of this symphony has the most powerful bass?
- If the final movement indeed has the deepest/strongest bass, do I feel that the bass is strongest in the "Poco Adagio" due to limitations in my subwoofer and/or characteristics of my room?
The signal path is CD to Onkyo TX-NR708 A/V receiver via optical, to HSU VTF 3.3 + Turbo via LFE cable.
intoflatlines is offline
Old 04-25-2012, 08:08 AM
Kal Rubinson's Avatar
Quoted: 677 Post(s)
Liked: 460
Your observations are correct. There is lower bass in the "Poco adagio" but it is much less loud than in the finale. It is the latter that impresses most people.
BTW, what recording of the SS3 do you have?
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Old 04-25-2012, 09:47 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Poco Adagio Second Movement was one of the pieces put out on a CD by HSU Research to test your HSU subwoofers. The CD was included with each purchase of a sub. It also had some 3rd octave-wide warble tone from 16 to 250 hz.
bsoko2 is offline
Old 04-25-2012, 11:53 AM
oztech's Avatar
Liked: 101
It was the Boston Civic Symphony conducted by Max Hobart 1983.
oztech is offline
Old 04-25-2012, 01:35 PM - Thread Starter
Ah, good to hear. The final movement is certainly much louder but the deep bass was not very impressive IMO, it might just be the recording I have? I have the CD by the Philidelphia Orchestra (http://www.amazon.com/Saint-Sa%C3%AB.../dp/B000LP4OII) but I do plan on purchasing the Boston Audio Society one which includes the Boston Civic Symphony recording I believe.
Very good to know! I wish I had the CD
I heard that that recording is one of the best, I want to get my hands on it!
Old 04-25-2012, 03:53 PM
obsi's Avatar
Me too.
Velodyne DD-18, dual Elemental Designs A7-450, dual SVS PB13Ultra custom, Axiom EP500v2, dual B&W PCS8 THX, dual Infinity Kappa Perfect 12VQ Avaserfi LowQ, Anthony Gallo TR-3
obsi is offline
Old 04-25-2012, 04:27 PM
ccotenj's Avatar
Liked: 101
kal, you got a favored mch recording of this?
- chris
ccotenj is offline
Old 04-25-2012, 08:01 PM
Quoted: 677 Post(s)
Liked: 460
???? New one on me.
Kal Rubinson
Old 04-25-2012, 08:08 PM
Quoted: 677 Post(s)
Liked: 460
For sound quality, I like the Eschenbach/Philadelphia SACD on Ondine. I also like the classic Living Stereo with Munch/BSO/Zamkochian
and the Living Presence with Paray/DSO/Dupre.
Kal Rubinson
Old 04-25-2012, 09:52 PM
oztech's Avatar
Liked: 101
oztech is offline
Old 04-26-2012, 01:10 AM
douglas_ben's Avatar
I love the SACD, not just because of higher resolution/clarity, but the fact that the mastering is typically better than typical CD.
douglas_ben is offline
Old 04-26-2012, 05:31 AM
ccotenj's Avatar
Liked: 101
thanks as always...
- chris
ccotenj is offline
