Klipsch Promedia 2.1 woofer speaker replacement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-25-2012, 02:43 PM - Thread Starter
ricardobentes's Avatar
Hi!
Anyone knows where I can find a speaker for my klipsch promedia 2.1 subwoofer?
Mine is all ripped up so I want to replace it.
I can provide photos and measurements, not sure what info is needed.
Thanks in advance!
ricardobentes is offline
post #2 of 11 Old 04-25-2012, 02:49 PM
dunan's Avatar
Quoted: 62 Post(s)
Originally Posted by ricardobentes View Post
Hi!
Thanks in advance!
What kind of speakers are you looking for, the kind that go to the unit?
dunan is offline
post #3 of 11 Old 04-25-2012, 02:53 PM
drewTT's Avatar
Quoted: 719 Post(s)
Liked: 727
Hi!
Thanks in advance!
Did you try calling Klipsch for a replacement?
Probably be a challenge to find an aftermarket replacement if you don't know the OEM speakers T/S parameters.
LG OLED65E6 | NAD C368 | Dynaudio Special 40 + Stand 3x | Oppo UDP-205 | Maingear Drift Z170 GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+
drewTT is offline
post #4 of 11 Old 04-25-2012, 04:00 PM - Thread Starter
Hi guys!
Thanks for the replies.
I'm looking for just the speaker unit that goes inside the subwoofer box.
Please find attached the photos of the part.
On the back it just says B16AR90PF-01FW 0012.
I emailed Klipsch but they didn't answer me so far.
Thanks once again!
post #5 of 11 Old 04-25-2012, 06:22 PM
kesando's Avatar
Liked: 31
kesando is offline
post #6 of 11 Old 04-25-2012, 09:03 PM
Dezmond's Avatar
That can probably be refoamed if you did not blow the coil.Do you have a local audio shop ?
Dezmond is offline
post #7 of 11 Old 04-26-2012, 02:04 AM - Thread Starter
Great replies guys!
Ebay... feel so stupid, why didn't think of that before!
$25 is a great price.
Thanks a lot!
post #8 of 11 Old 04-26-2012, 02:06 AM - Thread Starter
I don't know of any audio shop around here, will have to look around. Do you think it will last longer than a new / replacement speaker? Would it normally be cheaper or more expensive?
post #9 of 11 Old 04-26-2012, 03:19 AM - Thread Starter
$47 in posting expenses... Too expensive.
I guess I'll have to take it to some audio shop if there is such a thing around here.
Thanks guys!
post #10 of 11 Old 09-15-2012, 11:06 AM
davednuker's Avatar
Have same [really nice] promedia 2.1 sound system, woofer speaker volume has dropped to maybe 10% and is distorted.
Opened back of woofer nothing obvious burned on the cicuit boards [but amp could still be blown] with speakers operating I felt woofer cone with my hand and was vibrating, so is getting some kind of a signal from amp, and so I am guessing [hoping] it is a blown speaker.
I didn't like the idea buying used Klipsch woofer on Ebay, so I ordered Dayton DA175-8 7" Aluminum Cone Woofer on Amazon for around $30. I should get the Dayton woofer in about a week, I will try to post an update on whether it worked and [if so] how it sounds.
davednuker is offline
post #11 of 11 Old 12-30-2012, 06:52 PM
sqrl007's Avatar
So how did the Dayton replacement work out?
Samsung UN75HU8550
Samsung SEK-3500u 2015 UHD Evolution Kit/OCB
Yamaha Aventage RX-A1050 AV Receiver
sqrl007 is offline
