Sub for Pioneer VSX-821 Recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-27-2012, 06:27 AM - Thread Starter
Thyrane's Avatar
Hi, first time posting i the audio part of the forum. Was wondering if I can use a Lava subwoofer LSP12 ( http://www.lavasubs.com/12_inch/powe...subwoofer.html ) with my VSX-821 with no problems. I'm not looking to spend anymore money than this. I'm using a pair of Polk Audio Monitor 60s and a pioneer subwoofer (I think it's a psw-8, it's the 8" model) and am VERY unhappy with it, probably because my room is too big (10x15 about). Any thought or recommendations would be much appreciated. Primary use will be music.
Jim
Thyrane is offline
post #2 of 4 Old 04-27-2012, 06:59 AM
ccotenj's Avatar
Liked: 101
yes...
- chris
ccotenj is offline
post #3 of 4 Old 04-27-2012, 09:34 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 2994
Agree. The Lava 12" will be fine with your receiver and should work much better than the Pioneer 8".
If you contact Lava and let them know you are an AVS member, they used to give a small discount.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 4 Old 04-27-2012, 03:22 PM - Thread Starter
Thyrane's Avatar
Wow, thanks for letting me know about this. I had no idea about this. Thanks for the replies, I really do appreciate it.
Thyrane is offline
