Best Sub for $200 to $250 to go with a Denon 1712 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-27-2012, 08:34 AM - Thread Starter
Alpharettaboomer's Avatar
Currently driving a set of KEFIQ70 with its matching IQ60 Center and a Denon 1712 Looking for a sub to go with this set.... Looking for something of grat quality that is musical and clean....
Options:
Energy 10.3 from Newegg $229
Velodyne Impact 10 from Electronic Expo $229
PA-120 $259
Any other choices I should consider... trying to stay within my budget. I hear the Energy 10.3 has a very bright Blue Light. Is that a concern? THank you ...
Alpharettaboomer is offline
post #2 of 7 Old 04-27-2012, 10:07 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
Your budget for the sub does not match up to the quality of your other speakers. Those are good budget subs you have listed, but I would not consider them the same class as the speakers you have. Subs cost more because they are a speaker and an amp.
I would recommend you wait until you can afford one of the 12" subs from the major Internet direct vendors, such as the Epik Legend, Rythmik FV12, or Outlaw Audio Plus (which is currently on sale through the weekend).
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 7 Old 04-27-2012, 10:15 AM
mrminsky's Avatar
I thought these were decent subs..Thank you for your heads up on these. BUT I DO NOT KNOW ANYTHING ABOUT SUBS... WOuld Klipsch Reference 12 or 10 be an upgrade over these or A kEF Kouro 1
mrminsky is offline
post #4 of 7 Old 04-27-2012, 10:25 AM
cel4145's Avatar
Liked: 2990
The Internet direct sub retailers you see mentioned on this forum are the best bang for your buck at their price point. The Klipsch Reference RW-12d is a good $300 sub (when you can get it for that), but it is not the same class as those other three I listed.
cel4145 is offline
post #5 of 7 Old 04-27-2012, 02:38 PM - Thread Starter
All those subs are quite a bid more than I can spend right now....... Thank you for your input..... Maybe I keep an eye on the Klipsch Reference which is close to my budget.....
post #6 of 7 Old 04-27-2012, 02:45 PM
cel4145's Avatar
Liked: 2990
The RW-12d is known for being excellent for HT for it's price because of its frequency response and SPL output, but it's not considered the most musical sub.
cel4145 is offline
post #7 of 7 Old 04-28-2012, 12:29 PM
cel4145's Avatar
Liked: 2990
Newegg just put the RW-12d on sale for $329 through tomorrow, promo code EMCYTZT1503.
cel4145 is offline
