Sub Recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-28-2012, 04:05 PM - Thread Starter
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Looking for a good sub for the following:
$800 budget, 3500 cubic foot room, primary ht use, listen at high volumes, no appearance requirements and flexible on timeline.
I've been looking for weeks and like the SVS PB12-NSD and the HSU VTF-2 MK4 but I'm torn. I'm replacing a Klipsch Sub-12 that had great punch in my old home, but is lacking now in my larger space. I'm looking for a hard hitting sub that also has good mid-bass.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Oppo UDP-203
Tom Riddle is offline
post #2 of 12 Old 04-28-2012, 04:15 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 508
HSU VTF-15h if your a little flexible on the 800. I would save up a little more to get that sub if you already have 800. Would be well worth it.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #3 of 12 Old 04-28-2012, 04:32 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Another option that will excel above 30hz is a CHT SS18.1 with a Behringer EP2000 power amp. That will also allow you to add a 2nd sub down the line for only $550.
Edit: This amps an even better deal and puts your right at your budget.
http://www.guitarcenter.com/Behringe...97-i2267784.gc
Jay1 is offline
post #4 of 12 Old 04-28-2012, 05:12 PM
dpc716's Avatar
Quoted: 13 Post(s)
Liked: 24
Suggestions provided so far have been good ones. Consider the Epik Empire also. It has excellent mid bass, only shipping costs put it over your budget. It would dust the Klipsch over 30 hz.
The subs you're considering are all better than your Klipsch, but may not exceed it by the order of magnitude you're looking for.
dpc716 is offline
post #5 of 12 Old 04-28-2012, 06:03 PM
brian6751's Avatar
Quoted: 1140 Post(s)
Liked: 1120
I agree except I think the sealed recommendations would run out of steam in that size room. Although I like the Chase idea since it would be very easy and cheap to add a second one down the road. Two of those would rock that room.
To answer the original question. $800 limit. That size room. Pb12-nsd all day
That's not science! - Cyborg
FOR SALE: 120" 16:9 Silver Ticket AT Screen
Rivers Edge Theater
brian6751 is online now
post #6 of 12 Old 04-28-2012, 06:28 PM
dpc716's Avatar
Quoted: 13 Post(s)
Liked: 24
To get an idea of how the PB12 and Empire would compare, I'd suggest looking at the measurements here, using the Outlaw LFM EX with 2 ports open as a proxy for the PB12:
http://www.data-bass.com/data?page=systems
I've owned dual PB10's, which would exceed a single PB12 for output, and I can say above 30 hz or so its the Empire all the way. Between 20-30 hz they are comparable.
dpc716 is offline
post #7 of 12 Old 04-28-2012, 06:35 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4781
The PB12NSD can't keep up with the Empire. My Empire is in a bigger room than OP's and does just fine; the room's not sealed either. Empire has the advantage in the first place, and doesn't need to be ported. It does cost a bit more with shipping, tho. The 15H Hsu would also be worth spending a bit more on. Size does matter.
lovinthehd is offline
post #8 of 12 Old 04-28-2012, 08:58 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Either of the PB12-NSD or the VTF-3 MK4 would be just fine for that space. Check out this review from Audioholics of the PB12-NSD where it is rated in the end as good for rooms up to 5,000 cubic feet: http://www.audioholics.com/reviews/s...ofers/pb12-nsd
The VTF-3 MK4 is often compared to the Outlaw Audio LFM-1 EX, which got a similar rating from Audioholics and which has been demonstrated to have more output than the SVS. So all good there, too.
Two factors that you might consider are that the 3.4 should be able to get a little lower in frequency response when in maximum extension mode, and the PB12 has a limiter built in to keep you from accidentally pushing it too much. Personally, I think you could choose the one you want based on aesthetics and not do wrong.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #9 of 12 Old 04-29-2012, 04:21 AM
brian6751's Avatar
Liked: 1120
I mean run out of steam in the lower end but that's still strong stuff from fhe Empire. but the Empire is over $800.
Rivers Edge Theater
post #10 of 12 Old 05-01-2012, 11:28 AM - Thread Starter
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Thank you all for your replies and advice! I'm really leaning towards the SVS PB12-NSD. It seems to have everything I want. I'm going to have to pull the trigger on something before I drive myself crazy looking at all the options.
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #11 of 12 Old 05-01-2012, 07:24 PM
ingramba's Avatar
Quoted: 142 Post(s)
Liked: 116
....Got one almost 2weeks ago and couldn't be happier. Sounds better everyday I listen to it!
ingramba is offline
post #12 of 12 Old 05-01-2012, 08:10 PM
lovinthehd's Avatar
Liked: 4781
They're all good choices and you'll be smiling with any of them. The differences are not great in any case. We're fans of what we know first hand for the most part...
