Budget $400 sub - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Best for deep, clean bass for mid to moderatly high levels?
Cadence CSX12 Mark II 0 0%
Energy VSW-10 0 0%
PA-150 0 0%
Voters: 0. You may not vote on this poll
post #1 of 23 Old 05-01-2012, 08:13 AM - Thread Starter
CtrlAltElite's Avatar
Cant spend any more than $400. Looking for Deep clean bass. 14x24x8. Movies and music.
These are my options
-Cadence CSX12 Mark II
-Energy VSW-10
-PA-150
CtrlAltElite is offline
post #2 of 23 Old 05-01-2012, 08:16 AM
mannoiaj's Avatar
PA-150 for the most output to fill the room. It won't get you the deepest bass though.
mannoiaj is offline
post #3 of 23 Old 05-01-2012, 09:42 AM
flickhtguru's Avatar
Liked: 110
BIC Acoustech PL-200.
Shawn
flickhtguru is offline
post #4 of 23 Old 05-01-2012, 09:44 AM - Thread Starter
No! I know form other people that the PA-150 is as good as two BIC PL-200. So 1 would get smoked by the PA-4150. So that's why I didn't include that.
post #5 of 23 Old 05-01-2012, 09:45 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
As a 10" sub, the VSW10 would struggle to perform in that size room.
None of these subs have good very good performance below 30hz, so you might was well go with the one with the highest SPL, the PA-150.
However, since you were previously thinking about the SVS PB12-NSD in your other thread, I would recommend the Outlaw Audio LFM-1 Plus that is on sale for $499 shipped through May 4th. It has solid performance down below 20hz, which is good for HT usage, and plenty of output for that size room.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #6 of 23 Old 05-01-2012, 09:57 AM
Liked: 110
I'm not arguing as I never head either. But both have basically the same specs. Same power ratings on their amps and the PL-200 digs 3hz deeper according to specs only. Now yes the PA is a 15" and the PL-200 is a 12" but I have a hard time believing that it takes 2 PL-200s to keep up with 1 PA 150.
Shawn
post #7 of 23 Old 05-01-2012, 10:04 AM - Thread Starter
me too lol. But apparently there is a thread about this very topic. Just going by what the testers and other people with the data have. Im not making this up.
post #8 of 23 Old 05-01-2012, 10:05 AM
cel4145's Avatar
Liked: 2991
We have test data. Check Ricci's max long term averages for 20hz to 80hz: PL-200 (101.4 db) and PA-150 (107.2 db) (look at the other range responses, too). So you'd have to collocate the PL-200s to equal that.
cel4145 is offline
post #9 of 23 Old 05-01-2012, 10:07 AM
Liked: 110
OK...... But I agree with cel.... Stretch your budget and buy the Outlaw Audio LFM-1 Plus. I have 2 of them they are nice looking high WAF subs with the plexiglass inlaid top and they sound amazing for the price. I also bought mine on sale.
Shawn
post #10 of 23 Old 05-01-2012, 10:09 AM
Liked: 110
Ok that looks like proof to me.... Prime example why one should never let specs alone determine what they buy.
Shawn
post #11 of 23 Old 05-01-2012, 10:19 AM
cel4145's Avatar
Liked: 2991
And here are good graphs for the OP to follow up this discussion in other ways.
Here is the frequency response of the PA-150 and the PL-200 (what we know about the Cadence so far suggest it's probably similar) also from that same site by Josh Ricci I linked to above, a reviewer for Audioholics. Notice how peaky they are in the mid-bass range. A tremendous variance That means if you crossover your speakers at 80 or 60hz, you will get much, overemphasized mid-bass and then it will taper off such that you won't get good solid output below 30hz.
Then look at the Outlaw EX which will be similar to the Plus. You get two different port mode options depending on whether you want to emphasize more output or deeper extension, both of which will give you a much flatter response down below 30hz. So you'll be able to feel those lower bass effects well while also getting good mid-bass.
cel4145 is offline
post #12 of 23 Old 05-01-2012, 02:15 PM
thebriman's Avatar
I would choose this option as well. In the long run I cant imagine you regretting it. Big step up from your listed subs to the Outlaw.
thebriman is offline
post #13 of 23 Old 05-02-2012, 06:50 AM
skally's Avatar
I can give my experinace on the $400 subject, but just keep in mind this is "my opinion" . If $400 is the TOP the OP has to spend then the PA-150 gets my vote. Now... if the OP is willing to spend another $100 then I would suggest the Outlaw Plus as Cel4145 mentioned. Heres what I have had and have....
Had...
Dual Pl-200's = Great units for the price of $250/260, so I had no regrets as they performed quite well at the time for my HT area. I read Ricci's test results last year for the PA-150 so I thought I would order that to add another.
Had Dual Pl's & have PA-150...
I believe the Pl's "maybe" would dig a bit deeper in the LF but it was hard to tell without a SPL meter at the time but when the LF would hit around the 30(+/-) mark is where the PA would shine over the PL's in a big way. To me it was close enough to say "it was a night & day differnace" so I will just leave it at that.
Have Pa-150 & Outlaw EX...
When it comes to LF the Outlaw outperforms the PA-150 without a doubt. You can feel the bass without hearing it is the best way to descibe it. When it gets into the mid bass as I will call it say 35 & up is where the PA will shine, not a night & day differnace by no means but to me I would say the PA has more "umph"... or at least it seems like it to me anyhow.
For now I will just leave it at that as I have to head to work. Have a great day!
skally is offline
post #14 of 23 Old 05-02-2012, 07:10 AM
wingnut4772's Avatar
Liked: 29
This.
Kaboom.
wingnut4772 is offline
post #15 of 23 Old 05-02-2012, 08:52 AM
Noman74656's Avatar
Quoted: 69 Post(s)
Liked: 98
I am in the market for a budget sub. I "think" I have narrowed it down to the polk psw505 or the energy s10.3. Which is better for maintaining the sub 30hz frequencies?
My theater room is about 3000 cubed feet, signal is coming from a denon Abe-791. My front setup is two Polk monitor 60c's, cs1 center, rm8's for the heights, and soon to be mirage satellites on the sides. Suggestions?!?!?
"In nature there are neither rewards nor punishments; there are consequences."Robert Green Ingersoll
Noman74656's Martycube Builds
My Theater
Noman74656 is online now
post #16 of 23 Old 05-02-2012, 08:58 AM
cel4145's Avatar
Liked: 2991
Which makes complete sense based on the difference in frequency response. If one uses room correction software on a receiver to calibrate their sub or an SPL meter, that will measure the output over a wide frequency range. So because the PA-150's output is heavily weighted in the mid bass, it's going to have more oomph there once calibrated. A sub like the Plus or EX, because it's a more even across the frequency range, would end up with the mid bass is a little lower because the very low end is producing more output to reach the same average output total across the same wide frequency range.
cel4145 is offline
post #17 of 23 Old 05-02-2012, 09:10 AM
cel4145's Avatar
Liked: 2991
Here's a chart that shows the frequency response for the S10.3 (the blue line). And here's a review of the PSW505. The first graph would be the ones to compare against the S10.3 graph. The S10.3 is listed with a -3db point of 27hz. The PSW505 is -3db at 35hz, and by 27hz is about -10db down. So you wouldn't hear/feel the PSW505 as much below 30hz.
However, I would be worried that the S10.3 might not have the necessary total output for that room if you are listening to it fairly loud.
cel4145 is offline
post #18 of 23 Old 05-04-2012, 08:56 PM
Noman74656's Avatar
Quoted: 69 Post(s)
Liked: 98
Thanks for the info, I am really fighting the urge to buy an outlaw plus....
Must..... stay ....within budget.....
My Theater
post #19 of 23 Old 05-04-2012, 09:13 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
Jl f113
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #20 of 23 Old 05-04-2012, 10:20 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Klipsch RW12D only $300 shipped through the weekend. Will go deeper then all of these subs.
Jay1 is offline
post #21 of 23 Old 05-06-2012, 02:11 PM
amazonracer's Avatar
Compare to PA-150?
amazonracer is offline
post #22 of 23 Old 05-06-2012, 02:23 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Originally Posted by amazonracer View Post
Compare to PA-150?
PA-150 drops 20db from 60hz to 25hz. It's another mid bass blaster just like all the BIC subs.
Jay1 is offline
post #23 of 23 Old 05-06-2012, 02:32 PM
pokekevin's Avatar
Liked: 102
For out put the PA 150. If you could get (somehow) 2 PL 200s I'd prefer that . Yes the 150 has more output but the room can change the sub alot and I'd rather have a more consistent response
pokekevin is offline
