Pioneer SW-8 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-07-2012, 09:57 PM - Thread Starter
keanon's Avatar
Piece of junk? Was hard to say no to it given its price and my budget. If it is junk, what would you recommend instead at not much higher a price?
keanon is offline
post #2 of 10 Old 05-08-2012, 12:03 AM
vraxoin's Avatar
Quoted: 16 Post(s)
Liked: 36
Ugh, it's not a piece of junk. You need to make sure that you aren't putting it in a room that is too big and/or a bass black hole (looking at you Archaea ). It is a simple, well made 8" ported 50w RMS sub, not a miracle worker. For $80-$90, it is hard to go wrong.
vraxoin is offline
post #3 of 10 Old 05-08-2012, 04:51 AM
kgb540's Avatar
Location: Left of the right coast and right of the left coast.
Exactly! Some people have been pretty critical about this sub, but for under $100 it is a solid buy.
kgb540 is offline
post #4 of 10 Old 05-08-2012, 05:09 AM - Thread Starter
keanon's Avatar
I have Smallish room. My receiver has an LFE output, and the sub only has line level RCA inputs, marked left and right. Do I just run one RCA cable from the LFE out to one channel of the sub? Or some kind of splitter?
keanon is offline
post #5 of 10 Old 05-08-2012, 05:25 AM
jackbuzz's Avatar
Manual says to use the left input.
jackbuzz is offline
post #6 of 10 Old 05-08-2012, 08:22 PM
Archaea's Avatar
Quoted: 3086 Post(s)
Liked: 2714
Me?
No?
Whatever are you talking about? ;p
http://www.avsforum.com/avs-vb/showt...2#post21820292
Archaea is offline
post #7 of 10 Old 05-09-2012, 01:21 AM
vraxoin's Avatar
Quoted: 16 Post(s)
Liked: 36
Me?
No?
Are you not the droid I'm looking for?
vraxoin is offline
post #8 of 10 Old 05-09-2012, 07:22 AM - Thread Starter
keanon's Avatar
Me?
No?
Post that new test result!
keanon is offline
post #9 of 10 Old 05-09-2012, 11:28 PM
Archaea's Avatar
Liked: 2714
Its up but it might not be what some want to hear.
Archaea is offline
post #10 of 10 Old 05-14-2012, 05:41 AM - Thread Starter
keanon's Avatar
Went with a BIC v1220 in the meantime.
keanon is offline
