SVS SB12-NSD and PB12-NSD - question for Ed Mullen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-11-2012, 07:15 PM - Thread Starter
syswei's Avatar
MODERATOR PLEASE DELETE THIS THREAD...I'm going to re-post in the SVS owner's thread
Could you please detail the output differences between the SB12-NSD and PB12-NSD. If you have them, graphs would be great. Or if not, output (or output differences) at various points, 25Hz, 30Hz, etc.; also indicating the methodology please.
Would also be very interested in any data/description concerning differences in the distortion realm, between the two.
Thanks in advance for any help.
syswei is offline
post #2 of 5 Old 05-11-2012, 07:45 PM
pokekevin's Avatar
Liked: 102
Hes in the SVS owners thread all the time. You could pm him...
pokekevin is offline
post #3 of 5 Old 05-11-2012, 08:15 PM
Luke Kamp's Avatar
Quoted: 163 Post(s)
Liked: 227
He has commented on dual sb12 to single pb12. Co-located duals +6db.
http://www.avsforum.com/avs-vb/showthread.php?t=1407855
"Dual SB12-NSD will have more mid/upper bass slam/impact than a single PB12-NSD.
A single PB12-NSD will extend deeper and will have more clean output at the very deepest frequencies (18-25 Hz).
Which option is best for you really depends on your particular application (room size, listening preferences, and overall playback level)."
http://www.avsforum.com/avs-vb/showthread.php?t=1407172
"Dual SB12-NSD is a potent little package - considerably stronger than a single PB12-NSD down to ~32 Hz, within 3 dB @ 25 Hz, and only about 5-6 dB down @ 20 Hz.
And you get the benefit of overlapping room modes and a smoother FR at more listening positions. It's a really nice option for smaller room where low visual impact is desired."
Graphs for both are under the tech specs on each sub's webpage. Both have limiters so low distortion as seen by the pb on data-bass.
http://www.data-bass.com/data?page=system&id=66&mset=71
Can always e-mail or call SVS if don't get reply on SVS owners thread or here.
Luke Kamp is offline
post #4 of 5 Old 05-11-2012, 08:36 PM
SAVholic's Avatar
Another answer by Ed:
"That is correct - a single SB12-NSD can hit ~92 dB @ 20 Hz @ 2M GP per CEA-2010 measurement protocol."
"My English is not very good looking" - Celia Cruz
SAVholic is offline
post #5 of 5 Old 05-12-2012, 04:32 AM - Thread Starter
syswei's Avatar
Thanks for the replies guys, I'm going to re-post in the SVS owner's thread, and make my questions clearer.
syswei is offline
Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer
