KEF HTB2SE or Scandyna Ball - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-15-2012, 09:16 PM - Thread Starter
malnutrian's Avatar
Considering they are of similar price, and both aesthetically pleasing, what's a better choice in terms of sound quality?
(I am using KEF Ci160QS as in-wall LCR speakers, not sure if using KEF subwoofer as the same brand is a reason to choose...)
http://kef.com/html/hk_en/showroom/h...2SE/index.html
http://www.amazon.com/Scandyna-03808.../dp/B0022NHP6K
Thanks for your opinion.
malnutrian is offline
post #2 of 11 Old 05-15-2012, 09:23 PM
keyboardcat's Avatar
keyboardcat is offline
post #3 of 11 Old 05-15-2012, 10:22 PM - Thread Starter
malnutrian's Avatar
You mean you wouldn't recommend this?
post #4 of 11 Old 05-16-2012, 09:15 PM
I never heard Kef, but I saw a older video a few months ago showing another defective kef sub. You may have good luck with it. Will the store let you return it without a restocking fee if you buy it and don't like it? I hear that kef subs hit hard. I never heard of the other brand sorry. I see that scandyna is a little cheaper in price then the Kef sub. Both look pretty cool.
I will try to find more info on both for you. Sorry about the late response by the way.
post #5 of 11 Old 05-16-2012, 09:22 PM
Looking at descriptions of it online I found out this about scandyneball.
I couldn't find anyone who reviewed it.
Colours Black, White or Red.
- Power: 60 Watt (Class D amplifier)
- Shape: Abs enclosure conceived to compliment the drop, the Minipod or the Micropod SE
- Voltage: 100-240 VAC
- LED light: Shows Power on, standby, mute
- Inputs: Stereo RCA Jack
- Drive unit: 6 ½ long throw - 4 layer woofer
- Frequency: minus 3 dB at 48 Hz, minus 6 db at 40 Hz.
- Input sensitivity: Input @ 100Hz 200mVrms; 1.5% @ rate power
- S/N (rated power): >70dB
- THD: <0.3% @ 1 Watt, 1.5% @ rate power output
- Functions: Cross-over frequency adjust range 40Hz to 140Hz variable, phase: 0dg or 180dg (switchable), digital volume control (360 dg type)
- Remote control: Volume, mute, on/offff
- Protections: Short-circuit protection, over current protection, over temperature protection
- Dimensions (with spikes mm): 320W x 220H x 320D
I guess this review is similar to the htb2s
http://reviews.cnet.com/subwoofers/k...-32317403.html
post #6 of 11 Old 05-16-2012, 09:27 PM
I guess kef will have more bass cuz bigger sub woofer. A lot of people on here think you do better with svs and hsu subs. they are internet only dealers. I haven't ever heard them though.
post #7 of 11 Old 05-16-2012, 09:38 PM
drewTT's Avatar
Quoted: 823 Post(s)
Liked: 831
Bloody hell. That looks to be probably the worst buy in the subwoofer world...
LG OLED65E6 | ARC DSi200 | Dynaudio Special Forty | Oppo UDP-205 | Maingear Drift GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Synology DS916+ | Apple TV 4K
drewTT is offline
post #8 of 11 Old 05-16-2012, 09:41 PM
drewTT's Avatar
Quoted: 823 Post(s)
Liked: 831
I would suggest staying away from the boutique subs unless you don't mind spending big bucks to get good performance. Look at products from SVS, Outlaw, HSU, etc.
drewTT is offline
post #9 of 11 Old 05-17-2012, 08:13 PM - Thread Starter
malnutrian's Avatar
Haha thx. I will go for the kef. Hope that works w my kef in wall.
Btw, has anyone heard things like shouldn't match KEF w Pioneer amp VSX LX55 cuz the result is too "bright"? What does that mean and is it true??
post #10 of 11 Old 05-21-2012, 07:35 AM
Quoted: 995 Post(s)
Liked: 525
FWIW, I have both the flagship Scandyna sub (the BassStation, which is bigger and better than the Ball) and two HTB2's.
The HTB2 is the better sub than the BassStation, full stop. More output, cleaner, about the same extension (40Hz or so). So it should blow the crap out of the Ball.
Here's a thread with measurements of a system using two HTB2's and a bigger sub. While I no longer use that configuration, it sounded as great as the measurements indicate. The thread includes individual measurements for the HTB2's at two different spots in my room.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #11 of 11 Old 07-31-2012, 05:00 PM
praharas's Avatar
this is an old thread but i guess i'll contribute.
i own htb2se. great sub for a smaller room. If you have a big open plan room you may need to push the sub but overall given the design and size i think this sub is ok. I have since bought SVS and happy with them.
praharas is offline
