WAF and near field placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-17-2012, 04:53 PM - Thread Starter
Down's Avatar
If this has ever been covered before, please direct me to the thread. My search attempts proved fruitless.
I'm considering near field placement for a pair of LFM-1 Exs as kind of "coffee tables" on each side of my HT seating. Unfortunately, this would put the rear panel (switches, wiring, etc.) in very plain view. Has anyone encountered this problem and came up with an ingenious solution to covering these that looked OK?
Down is offline
post #2 of 7 Old 05-17-2012, 05:12 PM
brian6751's Avatar
Quoted: 1112 Post(s)
Liked: 1101
Not sure you would want to cover them. Might get them too hot. I would get a 90 degree power plug and a 90 degree RCA adapter for each one. That would make it look a little neater. I do that so I can get the sub closer to the wall. But it also looks cleaner IMO.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #3 of 7 Old 05-17-2012, 05:18 PM
henrich3's Avatar
Quoted: 576 Post(s)
Liked: 497
If you set Scarlett Johansson near the right front corner of your room, I guaranty that nobody will notice the wires...
henrich3 is offline
post #4 of 7 Old 05-17-2012, 05:27 PM
henrich3's Avatar
Quoted: 576 Post(s)
Liked: 497
...and if they do, I'll take Scarlett off your hands - no questions asked.
henrich3 is offline
post #5 of 7 Old 05-17-2012, 07:26 PM
vraxoin's Avatar
Quoted: 13 Post(s)
Liked: 36
Eesh! Talk about low WAF!
vraxoin is offline
post #6 of 7 Old 05-17-2012, 07:45 PM
Slackjaw747's Avatar
Quoted: 22 Post(s)
Liked: 35
"Turn that down! The bass is giving me a headache..."
Slackjaw747 is offline
post #7 of 7 Old 05-18-2012, 05:00 AM
flickhtguru's Avatar
Liked: 111
Just turn the sub so that the amp is facing the furniture your sitting on. Provide some room for the cabeling so its not bent too hard, and for the amp to disapate any heat.
Shawn
flickhtguru is offline
