Subwoofer Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-18-2012, 09:21 PM - Thread Starter
ashrafz's Avatar
I currently own a PSW505.
Im having issues playing it at loud volumes. When I do so the sub makes a very strange sound, like the cone is moving (like i can hear it physically moving).
Whats wrong? Also what sub would you reccomend as a suitable replacement in case it calls for it? I would like to spend under 500 for a used one.
ashrafz is offline
post #2 of 5 Old 05-18-2012, 09:51 PM
Leo King's Avatar
I'm not really sure about the strange sound you heard. If you heard the rattle from the voice coil, the spider might be damaged.
The BIC America F12, VK12 and PL-200 are excellent budget subs. Most people preferred the PL-200.
Leo King is offline
post #3 of 5 Old 05-19-2012, 03:24 PM
eaamon's Avatar
Quoted: 67 Post(s)
Liked: 26
I'm not sure but it sounds like you are running too much power and the speaker is bottoming out.
too much movement and passing it's x-max.
sure every body like loud sub sounds with a higher volume, but you can over do it.
eaamon is offline
post #4 of 5 Old 05-19-2012, 09:13 PM
YeuEmMaiMai's Avatar
over driving it or maybe the surround is torn?
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #5 of 5 Old 05-20-2012, 06:30 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
At under $300, many individuals in this forum recommend the BIC PL-200.
If you can get a good price, then consider a second 505. The 505 will not play quite as low as the PL-200.
At around $400, individuals like the Hsu STF-2 that is considered a step-up from the PL-200. The Hsu will be much more musical than the PL-200 (you need to read the PL-200 thread for comments from former PL-200 owners who have upgraded to the STF-2).
Check Josh Ricci's excellent reviews at www.data-bass.com.
Ricci also like the Premier Acoustic (~$400) which will play quite loud but has most of its frequency response above 35 Hz.
wwinkler is offline
