Difference between frequency range and frequency response? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-23-2012, 10:10 PM - Thread Starter
Briandl's Avatar
These are the specs of my subwoofer:
Frequency range -6dB at 20Hz and 25/140Hz adjustable
Frequency response ±3dB 27Hz - 40/140Hz adjustable
So does it go down to 20hz, 25, or 27hz?
Briandl is offline
post #2 of 6 Old 05-24-2012, 05:36 AM
eljaycanuck's Avatar
Quoted: 1226 Post(s)
Liked: 1798
Frequency response refers to the range of frequencies a sub can play within a given sound-pressure variance (usually +/-3dB). So, for example, a sub rated 20-120Hz +/-3dB will play "flat" between 20Hz and 120Hz with a variance in sound pressure of no more than 3dB higher or lower.
It appears that your sub's FR is 27-140Hz +/-3dB. The manufacturer appears to have added a -6dB point of 20Hz to indicate that the sub will extend down that far, but the 6dB decrease in sound pressure means that output at that frequency will most likely be anemic compared to output between 27Hz and 140Hz.
eljaycanuck is offline
post #3 of 6 Old 05-30-2012, 10:54 PM
eaamon's Avatar
Quoted: 67 Post(s)
Liked: 26
a upward change of 3db is a doubling of volume.
so yours off 6db at 20Hz...guess what....
eaamon is offline
post #4 of 6 Old 05-31-2012, 12:20 AM
thehun's Avatar
Quoted: 636 Post(s)
Liked: 527
Actually most MFR specs on subs are quiet meaningless, because they almost never explain how they were obtained.
De sagittis Hungarorum libera nos, Domine!
The Hun
thehun is offline
post #5 of 6 Old 05-31-2012, 08:43 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
A change of 3 dB implies doubling of power, assuming the driver stays linear, or doubling the radiating area without increasing power. In the midrange 3 dB is about one notch louder to most folks. Doubling perceived volume in the midrange requires a 10 dB increase and 10 times the power assuming the speaker stays linear. Because of the equal loudness curves, which show how human hearing differs at different frequencies the perceived difference of a 3 dB change will be larger in the bsss than it is in the midrange.
To the OP it looks like the mfr has made up different terms to name two different ways to describe the claimed performance of the sub. I would not fully trust either. They don't seem to fit together in the expected way.
JHAz is offline
post #6 of 6 Old 05-31-2012, 04:10 PM
AVrebel's Avatar
If they all followed a "gold" standard it would be great.
Room placement, sub enclosure, room size, room treatments, furniture coverings, distance from listener, etc.... all effect the frequency response.
Some manufacturers are better than others at giving this measurement. The good ones give more details about how the numbers were obtained.
resolution good....
AVrebel is offline
