SVS PB10 NSD paired with Paradigm Mini-Monitors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-25-2012, 11:45 AM - Thread Starter
hoffusmc_09's Avatar
I'm looking at possibly buying my younger brother a sub as a birthday present and am considering some different options. He's currently running Paradigm Mini-Monitors v6 and an old entry level Klipsch sub. I was hoping to only spend up to $200, so I'm thinking that used is going to be the best route to maximize value.
His listening habits are about 50% HT/Gaming and 50% music. The listening area is about 14x20x7. It is a carpeted room in a basement with dry wall ceilings and walls. There have been some room treatments to include Auralex foam panels and a couple Auralex bass traps.
I've done quite a bit of searching and reading and the SVS PB 10 seems like a solid value at this price point, but I would like to get some more specific input to aid my decision making. I found a listing of one for $250 OBO. I'm still waiting to hear from the seller which version the sub is. I will update the thread once I hear back. I have a couple questions:
-How good of a match would it be with the Mini Monitors?
-Does it have the tightness and articulateness for music to pair well with the Paradigms?
-Would it likely have enough output to fill the space of the listening area?
Thanks for reading and any and all feedback is much appreciated!
Ryan
hoffusmc_09 is offline
post #2 of 12 Old 05-25-2012, 11:52 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
I found a listing of [a PB10-NSD] for $250 OBO.
That sounds like a very reasonable price for a gently-used unit.
Since subs don't need to be "timber matched" to speakers, it would be a perfectly good match.
It may not be as tight and articulate as a sealed sub, but I found that the BASH-powered PB10-NSD I used to own was actually pretty good with music (better than the PB12-NSD I upgraded to) and great for HT.
-Would it likely have enough output to fill the [14x20x7] space of the listening area?
Yes.
eljaycanuck is offline
post #3 of 12 Old 05-25-2012, 12:21 PM - Thread Starter
Thank you very much for the input. Yeah my guess was it would match fine with the Mini-Monitors given that subs don't need to be timbre matched like the rest of the speakers. I just mostly wanted to make sure that the two were of roughly equivalent SQ. I had looked at a BIC PL-200 when I was looking at buying new, but I just felt like it really wouldn't have the musicality to pair with the Mini-monitors for critical listening.
I have a sealed Rythmik F15HP and love it, but unfortunately their subs are at a whole different price point and there aren't many out there on the used market. I also have been looking at used HSU and Outlaw models, but haven't been able to find anything in my limited price range unfortunately.
post #4 of 12 Old 05-25-2012, 02:12 PM
kesando's Avatar
Liked: 31
I agree that the PB10nsd would make for a great all around match for the mini monitors and at $250, a good deal. In the event that you cannot come across a solid used sub, the Energy S10.3 is a great place to start for a budget new sub. It tends to go on sale at times for as little as $200 on newegg.com
kesando is offline
post #5 of 12 Old 05-25-2012, 06:57 PM - Thread Starter
Thanks for the input. I have considered the Energy S10 as it seems to be a pretty good value. To what degree would the Pb 10 outperform the S10?
post #6 of 12 Old 05-25-2012, 08:19 PM
Liked: 1798
It's been a while since I had both subs, but while the S10.3 was (and is) a very impressive sub for its size and its price (when on sale for ~$200), the PB10-NSD played much louder much cleaner. It is the better sub.
post #7 of 12 Old 06-01-2012, 10:08 AM - Thread Starter
Thanks for the reply Eljay. The sub is from Dec 31 of 2009 and is actually a PB-10 ISD and it has the Bash amplifier. From what I've read the ISD seems pretty similar to the NSD with the difference being the driver.
In your guys opinions would the PB10 ISD still be a good buy for around $200?
post #8 of 12 Old 06-01-2012, 11:30 AM
Liked: 1798
IMO, yes, assuming:
- it's in very good (or better) cosmetic condition;
- it's in 100% working order; and, perhaps most importantly,
- you trust the vendor re. the sub's reliability (i.e., he hasn't had any issues with it).
post #9 of 12 Old 06-01-2012, 05:12 PM
warpdrive's Avatar
Liked: 48
the PB10 will play deeper and louder. The old Energy 12.3 would have given the PB10 a run for its money though. I had one of those and it was one of the few retail brand subs that delivered (for its price of around $400-500) and compared head to head with the PB10
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #10 of 12 Old 06-02-2012, 04:08 PM
kesando's Avatar
Liked: 31
It's still impressive what SVS could do with a 10" driver in a moderately price subwoofer. Does Energy have anything equivalent today to the 12.3? Perhaps that could be another sub worth looking into used.
kesando is offline
post #11 of 12 Old 06-02-2012, 10:28 PM
warpdrive's Avatar
Liked: 48
I would say the Energy 12.3/Mirage S12 was probably their best bang for buck sub they ever made. It was musical, clean, accurate and had decent extension for its (discounted) price.
post #12 of 12 Old 06-18-2012, 12:01 PM - Thread Starter
I ended up picking up the PB 10 for $200. I only had it for part of a night before I had to ship it out to my brother so my interaction was a bit limited, but overall it seemed like a very good sub for it's price point. He should be getting it tomorrow. Thanks again for all the replies and input!
