2 mid priced subwoofers vs 1 high priced. Please help - AVS Forum | Home Theater Discussions And Reviews
Old 05-26-2012, 11:07 PM - Thread Starter
karapuz's Avatar
Looking for 1 sub or 2 subs within $ 500-800. My 3.0 setup is Energy Veritas V6. 3 for the front, V5.2 for center and AVR Yamaha RX-A2010 9.2 channels.
Room size 12x 25' x 8'. Listening area is 10'x10', HT is in the middle of the room facing the long wall. Watching movies 40%, listening to music 50%, gaming 10%.
I live in an apartment - so most of the time I will be playing at low volumes - high level output is not as important as SQ. Good base and room filling are very appreciated. Small size factor is very important. A good look helps a lot, specially in case of 2 subs.
I need you opinions on the following subs (the sub might stay in the middle of the room in case of 2 it would be center of the room and diagonal corner and I would prefer piano gloss finish that will match my speakers and furniture without compromising of the sound quality). Please help me choose.
2 subs setup
2 x Energy VSW10 - $ 350 each + FS
2 x DefTech SuperCube II - $ 389 each + FS
2 x BIC Acoustech PL-200 - $ 330 each
or
1 sub setup
SVS PB12- NSD
SB12-NSD
Rhythmic F12
HSU VTF-2 MK4
Outlaw LFX-1 Plus
Emotive X-Ref 12
Epic Legend
Thanks for your time and help.
karapuz is offline
Old 05-26-2012, 11:18 PM
oztech's Avatar
Liked: 101
The VTF3MK4 is on sale right now for 659.00.
oztech is offline
Old 05-26-2012, 11:23 PM - Thread Starter
karapuz's Avatar
Thanks. I like it, but unfortunately it's too big. That is why I didn't include it.
karapuz is offline
Old 05-26-2012, 11:30 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Out of that list,I like the SVS PB12
ack_bk is offline
Old 05-27-2012, 05:28 AM
pokekevin's Avatar
Liked: 102
What are your size limitations? All those subs are a bit similar in size
pokekevin is offline
Old 05-27-2012, 06:11 AM
kgveteran's Avatar
Quoted: 365 Post(s)
Liked: 131
Rumor has it Newegg has Energy subs on sale 199.00 shipped
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
Old 05-27-2012, 08:18 AM - Thread Starter
karapuz's Avatar
Max Dimensions 16" W x 22" D, height doesn't matter. But the main question is: from which setup (1 sub vs 2 subs) for more or less the same money will I get more. Thank you.
karapuz is offline
Old 05-27-2012, 09:32 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
+1
Best choice in the list. The SVS PB12-NSD would work very well in that size room, and is a better sub for SQ and low frequency extension than your dual choices.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Old 05-27-2012, 09:39 AM
spyboy's Avatar
Liked: 47
AFAIK the Energy S10.3 is on sale for $189 through today. Coupon code EMCYTZT1649. You have to register at newegg before you can enter coupon codes.
spyboy is offline
Old 05-27-2012, 06:46 PM
ingramba's Avatar
Quoted: 111 Post(s)
Liked: 104
Originally Posted by cel4145 View Post
+1
...+1 for the SVS PB12-NSD, just love mine!
ingramba is offline
Old 05-27-2012, 07:50 PM
Nethawk's Avatar
Liked: 118
+1
Do you think just one in that size room (and positioned on the long wall)? I have the same question, although not so much cost but justification for two subs over one. My room is 20x34, and based on the research I've done there are few subwoofers that will singly produce sufficient bass to fill all 5500 cubic feet.
I'm not challenging your response, just trying to learn more.
Nethawk is offline
Old 05-27-2012, 08:01 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
You also have to consider the low frequency range of 2 cheaper subs versus 1 bigger sub. The bigger sub in most cases will go (should) lower
qguy is offline
Old 05-27-2012, 08:04 PM
skiman24's Avatar
I like the Two BIC PL-200 subs for your dual and yes they can go low!!!
skiman24 is offline
Old 05-29-2012, 01:14 PM
spyboy's Avatar
Liked: 47
The PL-200 is a pretty compromised unit. This is what Josh Ricci had to say about it.
"The PL-200 is a popular entry level home theater subwoofer often recommended to consumers on a strict budget. It is rather small and light and the tuning frequency lands at about 30Hz which works well for most light-duty home theater applications. The driver appears to be constructed with mediocre parts and a rather small lackluster motor. It seems more effort went into the cosmetics of the driver rather than parts that would perhaps provide better performance. The unit also looks pretty good cosmetically but indeed lacks in the features department. Overall, we feel the look, feel and output of the PL-200 is adequate for the value, but don't expect high performance from this $280 system."
Dual HSU STF's would be better. The HSU products don't sacrifice performance and parts quality for the sake of appearance.
The Energy S10.3 is also a higher performing sub that has been on sale for $199.99 quite often recently.
spyboy is offline
Old 05-29-2012, 01:47 PM
flickhtguru's Avatar
Liked: 110
For a 20X34 room I think you should look into dual subs in the $500-$600 each price range.
Shawn
flickhtguru is offline
Old 05-29-2012, 06:12 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
In that size room I would look into an HSU VTF-15H. My room is close to that size and a single 15H works well. I had two mid tier subs and the single VTF-15H easily outperforms the pair.
It has very clean output and can easily extend down well under 20hz without distortion.
ack_bk is offline
Old 05-29-2012, 07:05 PM
kgveteran's Avatar
Quoted: 365 Post(s)
Liked: 131
Do you have the freedom to put these two subs you speak of where they will work best or are you limited to a few locations.
Multiple subs simply help fill in the gaps of LF sound, and spread it out so across a typical multi seat LP you will have the same response. Wts, there are three choices, the Geddes method of three subs, the Welti-Devantier method of two or four subs, or a modifyed method that i used. You can read it in my signature thread.
You should begin to aquire some measurement gear so you are not going into this blind. It seems that alot of science ends at the door, where it should actually continue. Setting up multiples is just about impossible without the proper measurement gear. With proper gear it is as simple as can be.
I dont have an opinion on any of these subs, just the methodology on setting them up. I really produced some great results using multiple subwoofers. good luck andpost your results...
KG
Old 05-30-2012, 07:39 AM
coolcat4843's Avatar
Quoted: 279 Post(s)
Liked: 105
I have two brand new SVS PB12-NSD subwoofers arriving today via FedX.
They'll be replacing two BIC America F12 subwoofers currently in my HT.
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
