What to use for in wall sub cables and wall plates? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-28-2012, 12:01 PM - Thread Starter
HTPCat's Avatar
Quoted: 499 Post(s)
Liked: 293
Doing some remodeling and will be installing in wall/ceiling speaker/subwoofer cables and wall plates. Will be making 3 separate subwoofer connection locations with the longest run 30'. Any recommendations what/where to buy for the sub cabling and wall plates?
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is offline
post #2 of 10 Old 05-28-2012, 12:04 PM
eljaycanuck's Avatar
Quoted: 1235 Post(s)
Liked: 1809
Any recommendations ... where to buy for the sub cabling and wall plates?
Monoprice.com
eljaycanuck is offline
post #3 of 10 Old 05-28-2012, 12:42 PM - Thread Starter
HTPCat's Avatar
Quoted: 499 Post(s)
Liked: 293
Originally Posted by eljaycanuck View Post
Monoprice.com
So would you suggest just getting terminated RCA cable and then using Female to Female RCA wall plate?
HTPCat
HTPCat is offline
post #4 of 10 Old 05-28-2012, 03:23 PM
oztech's Avatar
Liked: 101
RG6Q and use either the F connector to RCA or terminate the coax with RCA compression fittings.
oztech is offline
post #5 of 10 Old 05-28-2012, 03:28 PM
Liked: 1809
post #6 of 10 Old 05-28-2012, 04:36 PM - Thread Starter
HTPCat's Avatar
Quoted: 499 Post(s)
Liked: 293
What about Belden 1694A RG6? I could buy this in bulk unterminated and then use keystone F connector to RCA Female wall insert.
HTPCat
HTPCat is offline
post #7 of 10 Old 05-28-2012, 06:31 PM
SmokenAshes's Avatar
Liked: 53
Whats RG6Q? I can't find it on monoprice. What are the benefits of that over RG6/U?
SmokenAshes is offline
post #8 of 10 Old 05-28-2012, 06:47 PM
dunnmike's Avatar
Rg6q is quadra shielded coaxial cable. Usually bought at lowes or home depot.
dunnmike is offline
post #9 of 10 Old 05-28-2012, 07:33 PM
Liked: 1809
post #10 of 10 Old 05-28-2012, 09:14 PM
oztech's Avatar
Liked: 101
The benefits in quad shield are for long runs and the fact it may run close to other wiring in the attic or walls eliminating the chance of picking up interference.
oztech is offline
