Quick Ohm question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-29-2012, 11:51 PM - Thread Starter
Ronoman's Avatar
I am buying a theater system that I am going to be putting together my self, my question is can I have 8ohm mids with 8ohm tweeters with an 8ohm receiver, the obvious answer is yes, BUT I have an amplified sub that is on 4ohm, could I hook up the sub on 4ohm to the receiver and not break anything?
Also: Here is a link to my shopping carts
once i get 3 posts..
Ronoman is offline
post #2 of 3 Old 05-30-2012, 12:14 AM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
if you have an amplified subwoofer that is 4 ohm, it should have no effect on the receiver as you should be using the lfe output to the amplifier.
If by chance i misread and the sub is not amplified- I would strongly recommend against powering any kind of sub on a receiver's speaker outs.
stormwind13 is offline
post #3 of 3 Old 05-30-2012, 01:31 AM - Thread Starter
Ronoman's Avatar
You are correct about the amplification. What I'm doing is buying a subwoofer and then a plate amplifier so I can make my own box. To connect the sub I wire the LFE to the pre-out on the reciever?
Ronoman is offline
