Need help with subwoofer placement (pic inside) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-31-2012, 06:42 PM - Thread Starter
Lazarynth's Avatar
I have a Seaton Sound SubMersive HP subwoofer with 2400 watts and Dual opposed, 15" sealed subwoofer. It is hooked up to an Integra DHC 80.3 pre/pro and is used primarily for movies.
Here is my noob rendering of the theather room.
I am unsure where exactly to put the subwoofer for optimal results and would appreciate any input or areas to try out.
Thank you in advance, I look forward to your replies.
Lazarynth is offline
post #2 of 4 Old 05-31-2012, 07:11 PM
raehza's Avatar
Is that a door near the Screen? If yes, I'd place it near my seating position, in a corner behind. Best way is to do a subwoofer crawl (youtube this or google), to find the ideal spot for yourself, but a nearfield placement should be good in your room.
Ray
Projector: AE7000
Screen: 5x12 Wilson Art Laminate Designer White
Receiver: Denon 2112Ci
Fronts: DefTech 8020ST
Center: DefTech 8040HD
Side Surround: DefTech SR 8040 BPs
Rear Surround: DefTech PM 1000s
Subwoofers: 2x HSU VTF 15H's
raehza is offline
post #3 of 4 Old 05-31-2012, 09:49 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
bsoko2 is offline
post #4 of 4 Old 06-01-2012, 10:43 AM - Thread Starter
Lazarynth's Avatar
Ray
That is a door near the screen. Another thing, there is actually enough room below the screen to fit the SubMersive without getting in the way of the picture. The speakers also are under the screen which in reality is pretty lame since the listening position is considerably higher. The risers go up about 16 inches each so the speakers are very far off from being at ear level.
