Titanic MkIII and 1000w plate amp custom box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-02-2012, 09:49 PM - Thread Starter
Ronoman's Avatar
I just bought a Dayton Audio Titanic mk III 15" Sub, with a Dayton Audio 1000w plate amp and I'm going to be building a custom box for it, I want really deep powerful bass, I'm pretty sure I want ported, But I cant figure out what dimensions. Some people are saying almost 6cuft and others are saying 2cuft. Could you guys post some external dimension ideas?
Ronoman is offline
post #2 of 7 Old 06-03-2012, 07:35 AM
BillCinLR's Avatar
Better try the DIY forum.
BillCinLR is offline
post #3 of 7 Old 06-03-2012, 12:25 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
The Titanic really likes a large ported box, like 26"x26"x27" big (outer dimensions with .75" material). Throw a 6" x 17" port in there and you're at a 20hz tune.
Jay1 is offline
post #4 of 7 Old 06-07-2012, 12:53 AM - Thread Starter
Ronoman's Avatar
What kind of dimensions would I need for 2 4" ports? I'm really OCD about symmetry, and two ports would lower port noise right?
Ronoman is offline
post #5 of 7 Old 07-09-2012, 01:29 PM
nelson2000's Avatar
When you change the number of ports you don't change the box size if you like the tuning you change the port size. Usually longer. Go to this link and try Boxplot freeware. You can put in the number of ports and it automatically gives the new dimensions. http://www.speakerbuilding.com/software/ Good luck
nelson2000 is offline
post #6 of 7 Old 07-09-2012, 01:32 PM
nelson2000's Avatar
Also, larger ports will be less noisy but will need longer size to achieve the same tuning. The Boxplot will also give wind noise in Mach speed to guide you.
post #7 of 7 Old 07-09-2012, 02:41 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
A single 6" port has more area then a pair of 4" ports.
Jay1 is offline
