Subwoofer - Coax/RCA connection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-06-2012, 07:47 PM - Thread Starter
vivek1983's Avatar
My house is prewired for 7.1 channel sound system. They have provided coax for the subwoofer. My receiver has line level (RCA) inputs for subwoofer. I need advice on two connections, 1) from wall coax to receiver line level (RCA) and 2) on other wall, coax to subwoofer line level (RCA). Following are the links for my receiver and subwoofer.
http://www.amazon.com/gp/customer-media/product-gallery/B0002KVQBA/ref=cm_ciu_pdp_images_0?ie=UTF8&index=0&isremote=0
http://www.amazon.com/Onkyo-TX-Channel-Certified-Receiver/dp/B004O0TRD8/ref=sr_1_3?s=electronics&ie=UTF8&qid=1339033601&sr=1-3
vivek1983 is offline
post #2 of 7 Old 06-06-2012, 08:34 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
Your receiver has a RCA output for the sub. Use that subwoofer pre out in solid white. Buy two RCA cables from monoprice.com Plug one into your receivers lfe out and to the wall plate then plug the second from the other wall plate To either the left or right Line Ine connection on your sub.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #3 of 7 Old 06-06-2012, 08:39 PM - Thread Starter
vivek1983's Avatar
Will the RCA cable male end plug into coax female adaptor?
post #4 of 7 Old 06-06-2012, 08:45 PM
gregzoll's Avatar
Liked: 33
Go to Radio Shack and get a 'F' to RCA connector. It will basically screw on to the coax end, as if you were connecting the coax to a tv.
brian6751 likes this.
gregzoll is offline
post #5 of 7 Old 06-06-2012, 08:49 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
Missed that part. +1 on this.
Rivers Edge Theater
post #6 of 7 Old 06-06-2012, 09:16 PM - Thread Starter
vivek1983's Avatar
I tried to find this connector online. Can you send me link for the product, it will be very helpful.
post #7 of 7 Old 06-06-2012, 09:41 PM
Brocken_5110's Avatar
Receiver's Subwoofer Out (RCA Female) > RCA Male-Male Cable > RCA Female to F-type Male Adapter > F-type Female Port on Wallplate.
Subwoofer LFE In (RCA Female) > RCA Male-Male Cable > RCA Female to F-type Male Adapter > F-type Female Port on Wallplate.
Brocken_5110 is offline
