Gauge for cable run between amp and subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-08-2012, 08:54 AM - Thread Starter
beetlesnack's Avatar
I currently have an EP2500/4000 and a CS-18.1. They are together right now but I'm looking to move the amp into a cabinet. The speaker cable run will be 25-30 feet. I have a spool of 14ga in-wall cable which I understood to be OK for my 25-30 foot runs for the other speakers. My question is how much difference does it make that I'm now doing this for a subwoofer? There are so many more watts running through this thing, that it just seems small to me. But maybe it is fine, I have no idea.
beetlesnack is offline
post #2 of 2 Old 06-08-2012, 09:54 AM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
14 gauge is fine, but if 10 gauge would make you feel better, get some of that.
Take a look at the table in the Wikipedia article at http://en.wikipedia.org/wiki/American_wire_gauge
14 gauge has a resistance of about 8.2 milli-ohms per meter, so your 10 meter run would have a resistance of 0.082 ohms. (10 x 8/1000 = 8/100 ohms)
10 gauge would briing it down to almost 1/3: 0.033 ohms.
Selden
Selden Ball is offline
