Velodyne Impact 12 vs. Klipsch rw-12d, advice? - AVS Forum | Home Theater Discussions And Reviews
Old 06-10-2012, 09:37 AM - Thread Starter
Ozzie Isaac's Avatar
Liked: 101
I've scanned through threads and reviews. I do not have the option to hear either in person. Does anyone have pros/cons between the two? I have about 300 sq. ft room, but attached to another 400sq. ft I cannot close off. The room has 9ft ceilings and carpet. I want to stay under $400 for the first sub, but will probably wind up going a multiple sub approach. Can only sneak so much by the wife at a time smile.gif
Right now I have no subwoofer.
Ozzie Isaac is offline
Old 06-10-2012, 07:18 PM - Thread Starter
Liked: 101
Any advice? Or did I ask a dumb noob question and compare two completely different subs? This will be 50/50 music/movies.
Old 06-11-2012, 07:43 AM
JimWilson's Avatar
Quoted: 1276 Post(s)
Liked: 1592
The RW-12d is often cited as being good for HT, but isn't generally considered musical. What type of music do you listen to? If it's rap/hip hop, or something along those lines, it might be fine. For anything that requires a bit more detail it may not be the best choice.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
Klipsch Rw 12d 12 Subwoofer Each
