Question re: subs in large rooms - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 06-16-2012, 05:51 PM - Thread Starter
blakeyj08's Avatar
We'll be moving into a new home shortly, and the house is wired for 5.1 surround. I've never had a setup before, and everyone on this site has been extremely helpful in answering all of my questions. The room that the system will be in is sort of a big rectangle, with one half being the tv/living room (where the wires are), and the other end having the dining table and opening into the kitchen. There are 10' ceilings, so all in all the room is about 5,000 c.f., with the entertainment area being maybe 3,000 c.f. of that.
My question is - if I mainly want a sub just to fill in the low end of songs and movies, and not a sub powerful enough to shake the foundation and rattle my innards, what should I be looking for? It'll be used probably 80% tv/movies and 20% music, but we'd probably turn it up louder when listening to music if that makes a difference.
Obviously, having just bought a house, our budget is pretty tight. I've been looking at the Bic Acoustech PL-200 or the Polk PSW505. Are these good options? Too much? Too little?
What do you guys (and gals) think?
blakeyj08 is offline
post #2 of 21 Old 06-16-2012, 06:55 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Eh, you arent going to be able to properly fill a room that size with any $200-$300 sub. The sub sees the entire volume of your room. The best thing you can do is worry about getting a strong 40hz and up performance if you dont want to increase your budget. Something like this would be decent.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-770
Jay1 is offline
post #3 of 21 Old 06-16-2012, 08:35 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Just looked at your sub build Jay, nice work.
There you go OP, get Jay to make a "special" sub for your layout.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #4 of 21 Old 06-16-2012, 08:52 PM - Thread Starter
blakeyj08's Avatar
Hmmm... I hadn't considered building one from a kit before. How difficult is it? Does that kit include everything I need to have it working?
And man... that thing sounds like it would knock down the wall it's going to be next to. eek.gif
post #5 of 21 Old 06-16-2012, 09:08 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
It's really simple. Connect wire from amp to sub. Drop sub in place, install screws. Drop amp in place, install screws. Done. It's a powerful sub above 40hz, but since it's sealed and your room is huge, it wont pick up room gain. The ported subs in this price range wont really do much below 40hz in a room your size either, so you might as well maximize your output where the majority of content is.
Thanks. If OP was willing and able to build boxes, DIY would get him something pretty solid for $300.
Jay1 is offline
post #6 of 21 Old 06-16-2012, 09:32 PM
Skylinestar's Avatar
Quoted: 1056 Post(s)
Liked: 184
I have the same problem.
Is a single Rythmik FV15HP enough for a space that's about 8,000 cu ft & opened to staircase that leads to first floor of the house? The main listening area is about 3700 cu ft but it's fully opened to the dining room and kitchen (total ~8,000), and the stairs. I have e-mailed SVS before and the reply was to have at least two units of PC12-Plus to pressurize the big space.
Usage will be for movie...master volume at about -15 to -10 dB.
Currently I have a small Klipsch SW450 subwoofer. With my weird room size (L shape) and the big space, it's impossible to achieve a flat frequency response with a single subwoofer.
Any advice is greatly appreciated.
Skylinestar is offline
post #7 of 21 Old 06-16-2012, 09:57 PM - Thread Starter
blakeyj08's Avatar
I'm pretty handy with anything up to simple soldering. Once it gets more complicated than that I'm willing to learn as long as it's not overly difficult.
post #8 of 21 Old 06-16-2012, 09:58 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
That FV15 is a very nice sub, but it is hard to say whether a single one will get the job done. I am definitely a fan of running dual subs for multiple reasons. If you're okay buying a $1300 sub now, and then another one later, the FV15 would be a great choice. If you aren't interested in spending more then this amount, buying a pair of subs like the VTF3 might give better results.
http://www.hsuresearch.com/products/vtf-3mk4.html
Jay1 is offline
post #9 of 21 Old 06-16-2012, 10:01 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Do you have a size limit for a box? Being able to build a very large enclosure is where you can maximize performance for cheap. Let me know if you're interested and I can spec you out a $300 build.
Jay1 is offline
post #10 of 21 Old 06-16-2012, 11:07 PM - Thread Starter
blakeyj08's Avatar
Ah... I just learned what 'WAF' means on this board, and I think it'd be an issue with a large box. The width and depth are constraints - not more than 19" wide and 20" deep.
post #11 of 21 Old 06-17-2012, 12:07 AM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
Hi Blake,
Easier to ask for forgiveness than permission. WAF is a temporary condition, upgtadeitis is far worse.... wink.gif
Joseph
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #12 of 21 Old 06-17-2012, 01:31 AM - Thread Starter
blakeyj08's Avatar
Originally Posted by wlhungdude View Post
Hi Blake,
Joseph
Haha. True - plus the whole thing (buying a receiver + speakers + sub) isn't really wife approved, so why not pile it on while I already get the eye rolls, right? biggrin.gif I'm no audiophile by any means, but even I know our Viera sounds terrible. She seems to be fine with it though... rolleyes.gif
Really though the size constraints are due to the layout of the room - the TV wall is between the staircase and a short hallway. The receiver is in the closet directly behind the tv, so unless I wanted to do a wireless sub it has to be placed somewhere between the stairs and the hallway, plus we have a tv table to fit in there. The 19" x 20" is really as big as I can go without having it stick out into the hallway width-wise or past the tv stand depth-wise, unless I were to go wireless and put it in another corner of the room.
post #13 of 21 Old 06-17-2012, 01:42 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
If you're okay with a pretty tall box (like 40") you can still get a sub similar to the performance of a HSU VTF15 for $300. If it has to be more square you will be fairly limited, but still able to get solid performance. Size equals efficiency when it comes to deep bass, when things get smaller you have to throw more power ($) and woofer ($) at the problem to get the same results.
Jay1 is offline
post #14 of 21 Old 06-17-2012, 01:54 AM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
WAF is subjective...
That being said... the best placement in your 'space' can only be determined , IMO, is by utilizing the 'sub crawl'. Short of using measuring equipent, is to actually put the sub in the main listening position, yes.. in the seat... and actually crawling around on the floor, with your ears at the level your sub would be located, while playing bass heavy music you're familiar with, and wherever your ears tell you it sounds best, is the best location to place the sub. It really works.
And yes, pile it on... just say it's the 'best i can do, with what i have to work with' ... and then say that the next step up is "A Jericho Horn"
driver complement 6 X 18" woofers, 24 X 5" mids, 12 X 1" compression drivers
, $25000+ " and this is the best next option... and she'll cave... "look honey, I want the best available, within reason, just to make sure I do it right once.."
It worked for me... I'm gonna go Danley's next anyway, but it bought me some time.... wink.gif
Joseph
post #15 of 21 Old 06-18-2012, 02:14 AM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Very true. My wife has finally gotten to the point of compromise, so now, all I have to do is, make sure I tell her I have an order showing up so she's not caught off guard biggrin.gif
Set up:
post #16 of 21 Old 06-18-2012, 11:44 AM - Thread Starter
blakeyj08's Avatar
Interesting, and good to know. Unfortunately like I said there's really only one place we can put the sub, unless I were to get a wireless sub or a wireless adapter for a non-wireless sub (do they even sell those). I noticed on sellout.woot.com today they have the wireless 8" Polk sub - I'd be able to put that anywhere, but sounds like it'd be way too small for my room.
That...looks...awesome. Do they use those at sports stadiums? If not, they should.
post #17 of 21 Old 06-18-2012, 02:20 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
yeah, they mainly cater to huge churches, amphitheaters, sports arenas, etc. Anywhere you need big sound in a huge space....
They have a great portfolio of completed projects on their website.
Total overkill for a (most) home theater applications, but ... I like overkill. smile.gif
... someday...
post #18 of 21 Old 06-18-2012, 02:32 PM - Thread Starter
blakeyj08's Avatar
... someday...
Reminds me of the Italian Job when the kid wants speakers that will blow your clothes off
post #19 of 21 Old 06-19-2012, 09:25 AM
amazonracer's Avatar
Wouldn't the PA-150 be just as good or better at a similar price? It gets good reviews for what it's intended for.
amazonracer is offline
post #20 of 21 Old 06-19-2012, 09:41 AM - Thread Starter
blakeyj08's Avatar
PSW505 - $199 at Amazon ($249 now)
PA150 - $425 at Amazon
post #21 of 21 Old 06-19-2012, 04:40 PM
I think the PA-150 can be had less than $425 or at least it was several weeks ago. I recall seeing $299 with some sort of code. Maybe wrong though.
Bic Pl 200 Acoustech Platinum Series Subwoofer , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Speakers Subwoofers
