Polkaudio DSWmicropro 1000 any good - AVS Forum
post #1 of 2 Old 06-25-2012, 10:50 AM - Thread Starter
raymondeast's Avatar
Has anyone heard and tried this sub polkaudio DSWmicropro 1000 what do you think of it. It says it is 1000 watts and 2000 watts peak.
raymondeast is offline
post #2 of 2 Old 06-25-2012, 07:27 PM
Jon S's Avatar
Liked: 41
Depends on your room size... Although it has a lot of power, the driver is only 8" with a 8" passive driver... You are not going to get much air movement with that. Polk specs the sub down to 27Hz so realistically, you are looking at a 30Hz bottom... Also the specs shows that the maximum output at low frequency levels is only 92dB... That is not much of an output for a sub.
If it's not a BIG screen, it's not a theater...
Jon S is offline
User Tag List
