set levels with test disc or tones in AVR. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-25-2012, 07:25 PM - Thread Starter
capricorn kid's Avatar
Liked: 25
I saw this topic mentioned in another thread but cannot find it. I have been using the tones in my AVR to adjust my sound levels to all my speakers including my subs. Tonight I decided to use the THX optimizer that is on most THX movies and discovered that using my SPL meter, my center channel was 2 db higher and my left surround was 1 db higher. My sub was at the same level when using the AVR tones. What is the proper way to check your levels, using a disc or the tones in the AVR?
Klipsch Synergy 3 speakers
Dual Klipsch RW 12D subs
120" 16:9 screen
Sony STR-DG 720
Panasonic BDT 460 bluray player
Panasonic PT-AE 8000u projector
capricorn kid is offline
post #2 of 3 Old 06-25-2012, 09:00 PM
D.T.MIKE's Avatar
I like to use a test disc like AVIA since you will utilize all of your equipment in the signal chain the same as you would use in watching a dvd or listening to a music cd.
a3plew likes this.
D.T.MIKE is offline
post #3 of 3 Old 06-26-2012, 09:43 AM - Thread Starter
Liked: 25
That is the way I was thinking.
120" 16:9 screen
Sony STR-DG 720
