Thoughts on the Dayton Titanic T1203K? - AVS Forum | Home Theater Discussions And Reviews
Old 06-28-2012, 02:00 PM - Thread Starter
ed3120's Avatar
This is the 12" DIY sub kit from Parts Express. A friend of mine said that the speaker has very good specs for the money and that the kit overall is a great value. I haven't found any reviews on it in this forum.
ed3120 is offline
Old 07-02-2012, 06:12 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
The Parts Express kits are quite easy to put together, A number of individuals in this forum (widely here and there) have indicated that they get good bass from the kits. Other individuals build their own enclosure and use PE drivers and plate amps with very good success. You can check the DIY part of this forum.
In that price range, you might also consider the Hsu VTF2.4 or comparable offerings from Outlaw Audio.
wwinkler is offline
Old 07-02-2012, 06:47 AM - Thread Starter
ed3120's Avatar
Those were the other 2 subs I was looking at. I want it mainly for TV/Movies, not really music, so I'm wondering which is better for me. My room is a basement room with a concrete/tile floor (covered mostly with area rugs) that is 17' x 20' x 6.5' ceilings.
ed3120 is offline
