2 Subs w/ Phasing Issues..??? - AVS Forum | Home Theater Discussions And Reviews
Old 07-05-2012, 07:10 AM - Thread Starter
VinnyS's Avatar
Liked: 54
Hey Guys,
Almost done the theater and hooked up my subs and managed to do a walk around of the room when I found that the center of the room has a massive phasing issue. Now I had this ridiculous 2 foot indent in my basemen (I don't know why the architect design something like that) but it seems to mess things up for me. I've posted a drawing of the layout of the theater and marked where I don't hear bass anymore. I've tried every combination 0-180, 0-0, 180-0, and 180-180 and still nothing. I have a feeling I will have to move them or add bass traps in the corners.
Can you guys help shed some light and offer some advice on what I should try, or confirm that bass traps might in fact help in this situation?
Thanks guys
584
Get all your A/V News at: AVS Latest News
Like AVS Forum on Facebook
Follow AVS Forums on Twitter
AVSForum
Bringing the AV Community Together
VinnyS is offline
Old 07-05-2012, 07:14 AM - Thread Starter
VinnyS's Avatar
Liked: 54
Here's a pic of what it looks like so far....
398
AVSForum
VinnyS is offline
Old 07-05-2012, 07:16 PM
oztech's Avatar
Liked: 101
Have you tried the right rear corner since that has the 2 longest walls it should give you some good numbers.
oztech is offline
Old 07-06-2012, 12:33 PM - Thread Starter
VinnyS's Avatar
Liked: 54
Thanks Oztech, I will most definitely try that out tonight. I completely forgot about putting subs on opposing walls.
I still don't like the fact that there's a 2 foot wall in front of the left subwoofer but then again, I don't have much choice.
AVSForum
VinnyS is offline
Old 07-07-2012, 07:36 PM
erhurd's Avatar
Location: Buckeye, Arizona (Phoenix); USA; Planet Earth
Quoted: 61 Post(s)
Liked: 52
The first time I looked at your sketch my immediate thought was "why not place the sub in front of the door in the opposite right corner of sub #1?" As oztech suggested, you should get a much more satisfying and improved, smoother room response with that placement. Let us know your thoughts after you have tried it for a while. Best wishes!
Edwin R. Hurd
AVS Forums Lurker-In-Training!
My Tight-space A/V Setup
erhurd is offline
Old 07-07-2012, 10:07 PM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 711
The 2' recess is not hurting your bass. I also doubt the LF/RR setup will get you the results you seek. No harm trying, of course.
I would suggest also trying putting one sub dead center of the front wall, and the other on the center of the rear wall. Even if that is unacceptable in the long run, it's worth seeing how well it works to unify the response.
Have a look at this presentation from Todd Welti, Harman. It shows how different sub locations affect the uniformity of the bass in the seating area. If you can get it to be uniform, then the AVR's EQ will make it smooth.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
