KLIPSH OR ENERGY SUB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-05-2012, 09:15 AM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
which is the better sub klipsh rw 12 or the energy s10.3 subwoofer. newegg has them for a good price.do you think the klipsh is worth an extra hundred dollars over the energy sub
destiny 21 is offline
post #2 of 4 Old 07-05-2012, 10:48 AM
JimWilson's Avatar
Quoted: 1567 Post(s)
Liked: 2094
I suppose it depends upon what you're going to use it for, and how big your room is. The RW12d seems like it might be the better choice for someone who does mostly HT, or is looking for more "wow" factor. The S10.3 sounds as though it's probably a bit more faithful, so it should be a little better for clarity and music.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #3 of 4 Old 07-05-2012, 11:27 AM
Stylz25's Avatar
Dont get either....I would spend a bit more and get something that is going to last and sound better! My opinion....
Stylz25 is offline
post #4 of 4 Old 07-05-2012, 12:16 PM
Lazerboy2000's Avatar
Wow I have been looking into the same comparisons for the 2 subs and wondering if it's worth the extra $100 for the Klipsch. I currently have an Alison AL-10 that I'm looking to upgrade and it seems that both subs are fairly close.
Lazerboy2000 is offline
