BIC H-100 Died...what to replace it with? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 08-06-2012, 08:59 PM
kcnitro07's Avatar
Quoted: 12 Post(s)
Based on a picture of the back of one of these I found on another forum, the plate amp looks nearly identical to the plate amp on my F12 and V1220s. Both the F12 and V1220s have 3 switches and 2 dials Top switch is power, on/auto/off, second switch is phase 0/180, Next is a "volume" knob, then a crossover knob, at the bottom is a third switch that switches reveiver type from digital to prologic. Directly above that switch is the subwoofer IN and it says IN in big words, not sure where the "out" comes from when you say the switch is "in/out", but more than likely the IN you are seeing is the label for the subwoofer in jack that is right above that switch and the switch itself changes receiver type.
kcnitro07 is offline
post #32 of 36 Old 08-06-2012, 09:01 PM
grpape's Avatar
Originally Posted by cel4145 View Post
That 0 and 180 switch is the phase. Typically, you can put it on whichever one makes the bass sound louder.
Sorry. Not sure about the in/out for the crossover switch. You might ask in the owners thread for the PL-200.
You're right. It is the phase switch (din't catch that one). I have mine at 0* and the crossover knob all the way to 120. I guess the PL200 has a "in" or "out" switch. I believe (after reading some threads) the "in" is for internal crossover and "out" is for external (avr does the crossover).
grpape is offline
post #33 of 36 Old 08-07-2012, 11:26 AM
capricorn kid's Avatar
Liked: 25
The " in - out " switch is for the crossover control. Setting it to in will engage the internal crossover. In that set up you will use the knob on the PL-200. Setting the switch to out is the same as a bypass switch that disables the internal crossover. You can set it either way but it is best to use the crossover setting in the AVR.
Klipsch Synergy 3 speakers
Dual Klipsch RW 12D subs
Velodyne SMS-1
Sony STR-DG 720
Panasonic BDT 460 bluray player
Panasonic PT-AE 8000u projector
capricorn kid is offline
post #34 of 36 Old 08-17-2012, 07:43 AM - Thread Starter
jnick1's Avatar
Quoted: 56 Post(s)
Thanks, cel4145!
I have another question here...I just received an email from Newegg about a deal they have. I can get the Klipsch RW-12d for $300. What are your opinions? Is this sub better than the PL-200? Should I have my dad return the PL-200 and get this instead?
Yamaha RX-V675 | Primus 363s fronts | Primus 163 rears | Primus 351 Center | Rythmik LV12R Sub
jnick1 is offline
post #35 of 36 Old 08-17-2012, 09:37 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Sure. The RW-12d is a little bit better sub. But if your dad is happy with the PL-200, keep in mind he'd have to pay return shipping on it. Not cheap to ship a sub.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #36 of 36 Old 08-17-2012, 09:41 AM
flickhtguru's Avatar
Liked: 110
+1... Just keep the PL-200.
Shawn
flickhtguru is offline
