How exactly does the gain knob on subwoofers work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-09-2012, 12:10 PM - Thread Starter
Test123455's Avatar
Every time you raise it by a numbered increment, does it just raise it by a certain # of dbs? Thanks, trying to figure something out!
Test123455 is offline
post #2 of 6 Old 07-09-2012, 12:13 PM
DonH50's Avatar
Quoted: 1790 Post(s)
Liked: 1323
Depends on the sub but usually not; that is, there is no standard for dB/number. Many AVR controls are calibrated, however.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 6 Old 07-09-2012, 12:21 PM
omegaslast's Avatar
It's just amplifying the voltage given to it by the pre amp or receiver. Ideally your pre amp has enough voltage headroom that it isn't clipping the output signal which then would send a clipped signal for your sub to amplify. You should ideally try to keep your level on your receiver in the -2 to +2 range and then adjust your sub amplifier knob to get your desired output
thehun likes this.
omegaslast is offline
post #4 of 6 Old 07-09-2012, 02:05 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
+1.. AFAIK, there's no standardization even as to whether manufacturers use linear potentiometers or log scale. When you have a linear control at one half, you have 3 dB more to go. Almost all the usable part of the control is in the first quarter turn (only 6 dB - - most folks would say 2 notches louder or quieter) are above the quarter turn point.. Makes things seem powerful because they are loud at low settings, but also makes precise setting more difficult than it ought to be, especially if you're in the forst quarter turn. When you have a log pot at one half, you are at 1/10 power (roughly/theoretically, ignoring tolerances etc) meaning you are half as loud as it will be when you turn it up all the way.
JHAz is offline
post #5 of 6 Old 07-10-2012, 05:29 AM
thehun's Avatar
Quoted: 635 Post(s)
Liked: 525
This is about to sum it up. The gain control on a powered sub works the same way as on an power amps, but unlike those amps especially pro amps the markings are different, which could create confusion.However it's primary role is to aid calibration so I guess the numerical markings would act as as a point of reference for that process, but I wouldn't use it to determine any meaningful acoustical power by it however.
De sagittis Hungarorum libera nos, Domine!
The Hun
thehun is offline
post #6 of 6 Old 07-10-2012, 03:11 PM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 874
If Audessey calibration is used, from what I have been reading, raising the sub knob is NOT recommended after Audessey set up.
tvuong is online now
