Energy S10.3 hook-up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-10-2012, 08:36 AM - Thread Starter
AUGTO's Avatar
I'm reviving my old NAD 1600 pre amp and NAD 2400 amp for a 2.1 system.
I have Paradigm atoms for my speakers and of course the S10.3 sub.
My issue is there's not a sub out on my pre amp.
Is it best to split the left channel out of the pre amp to the amp and sub?
Or would it be best to run the speaker wires from the amp to the sub and then out to the speakers?
If I do this do I connect the speakers out "from" the amp and the "to" speakers on the same terminal of the sub?
Thanks for the help
AUGTO is offline
post #2 of 2 Old 07-10-2012, 09:30 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
I was curious recently about what to do in this situation where you only have one set of speaker outputs for a sub and speakers, and asked in the DIY section. Should be fine to hook the subwoofer up in parallel with the speakers using the speaker outputs on your amp.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
