Car Subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-12-2012, 06:19 PM - Thread Starter
The Jam's Avatar
I know they aren't discussed much here, but I'm interested in upgrading my Yukon's sound system, starting with a new sub (or two).
The question is, does anybody know any reliable subs under $200, or $100? I've been looking at some of Pioneer's and Kicker's models.
The Jam is offline
post #2 of 11 Old 07-12-2012, 06:37 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4780
What do you mean by reliable? You fear failure of the sub? Do you need a powered sub or you have a separate amp suitable to power a sub or two? Do you want a stand alone type unit or just the driver(s) to mount in the vehicle? Ported? Sealed?
I have an inexpensive 10" Kicker driver in a prefab ported box in my van powered by a dedicated amp (don't remember it's brand or rating off the top of my head, tho) and it suits my purposes. If you put your own together with some shopping you can probably do it for $250 or so. My brother put a powered Bazooka sub in his wife's car and I was pretty impressed with the sound and ease of install, too.
lovinthehd is offline
post #3 of 11 Old 07-12-2012, 07:06 PM
kcnitro07's Avatar
Quoted: 12 Post(s)
I've always been a fan of ininity kappa perfects...however, they aren't produced any more, so you'd have to look for used on ebay.
kcnitro07 is offline
post #4 of 11 Old 07-12-2012, 08:29 PM
gtpsuper24's Avatar
Liked: 100
http://www.creativesound.ca/details.php?model=SDX10
http://www.creativesound.ca/details.php?model=TRIO12
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-466
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-650
http://www.sonicelectronix.com/item_43820_Massive-Audio-Toro-122.html
http://www.sonicelectronix.com/item_45430_Morel-Primo-124.html
Just about any sub can be reliable, it depends on how you use it. Like trying to use a SQ subwoofer like the Morel Primo as a competition SPL subwoofer. Or using a larger than recommended box, ect...
Kicker isn't that great IMO, the round subs are ok but the squares I would stay away from. The lower end Pioneer stuff isn't any thing special for the price the SDX 10, Trio 12, or the others listed will blow them away. If you stretch your budget about $50 you might be able to pick up a Boston Acoustics G5 or Polk Audio SR subwoofer.
This forum is a really good place for car audio, very knowledgable people there. http://www.diymobileaudio.com/forum/
gtpsuper24 is offline
post #5 of 11 Old 07-12-2012, 10:27 PM - Thread Starter
The Jam's Avatar
Thanks a ton guys for the info, and for the link in the last post.
Just to clarify, I'm not really sure as to what I want in terms of ported vs sealed, standalone vs mounted. I don't really have much preference of powered vs passive, but I understand powered will be easier.
Is the difference between ported and sealed like it is in HT subs (to the same degree?), or not? I'm going to have a lot of space in my trunk, seeing as the car probably has the largest amount of space aside from maybe an Excursion.
The Jam is offline
post #6 of 11 Old 07-13-2012, 11:21 AM
Scottyb09's Avatar
Quoted: 35 Post(s)
Ported enclosures tend to provide a more 'boomy' sound while closed/non-ported enclosures tend to sound a bit tighter. In my Camry I have a 12" dual voice coil Alpine Type-R sub in an enclosed box and it sounds fantastic (paired with 6 1/2" component Type R speakers in the front, an Alpine head unit running Audyssey MultiEQ, all powered by two amps). The Audyssey unit provides a world of difference!
Scottyb09 is offline
post #7 of 11 Old 07-13-2012, 11:42 AM
lovinthehd's Avatar
Liked: 4780
Your Yukon has a trunk?
post #8 of 11 Old 07-14-2012, 06:18 PM - Thread Starter
The Jam's Avatar
It's this: 399
The Jam is offline
post #9 of 11 Old 07-14-2012, 06:28 PM
lovinthehd's Avatar
Liked: 4780
It's this: 399
Great pic....my brother has a white XL....but it ain't got no trunk. smile.gif
post #10 of 11 Old 07-14-2012, 06:41 PM - Thread Starter
The Jam's Avatar
Haha not mine, but the same exact thing. How doesn't he have any cargo space? I just mean the back when I say trunk.
The Jam is offline
post #11 of 11 Old 07-14-2012, 07:33 PM
lovinthehd's Avatar
Liked: 4780
You know not even sure if he's bothered with anything but the stock sound system but there's no trunk in most SUVs; the trunk cavity can be part of the bass system which is why it's significant.
ps Now when it comes to entire volume interior my van is waay bigger (long wheelbase 15 psgr).
