Using high level input via B speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-17-2012, 07:46 PM - Thread Starter
dmsdms's Avatar
Liked: 30
Hello,
I have a Marantz PM6004 and I'm using the high level outputs to connect to a Hsu sub. When I wired it up, the easiest way to use the high level outputs was to just put banana plugs on the speaker cables, plug the sub into the Speaker B terminals and then run the amp with speakers A and B both active (actual speakers on A, only sub on B). This seems to be working fine and I haven't noticed any problems (amp is cold to the touch after 8 hours of listening) but, I'm wondering if this sort of setup can damage or otherwise affect the amp. The Hsu manual says using the high level outputs doesn't put a drain on the amp but, I don't know if that still holds true in this configuration. I search and couldn't find a definite answer so, any advice would be appreciated.
(Wasn't sure if I should post this in the sub forum or receiver forum...)
dmsdms is offline
post #2 of 3 Old 07-17-2012, 08:23 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
the a and b terminals are simply parallel wiring on a switch, so it is no different from using a Y cable. The input to the sub has a very high impedance and the sub draws very little current. no problem.
JHAz is offline
post #3 of 3 Old 07-17-2012, 08:58 PM - Thread Starter
dmsdms's Avatar
Liked: 30
Excellent, thanks. I had a feeling that was the case but wanted to verify.
dmsdms is offline
