BIC V1220 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-22-2012, 05:46 PM - Thread Starter
netconcepts's Avatar
Just purchased a BIC V1220 as a replacement for my Velodyne SPL10. What intrigued me was the low end frequency responce. 23 HZ is real close to the SPL10. While I loved my Velodyne, the longevity of this brand sucks. After two amp blowouts, its now an expensive door stop.
Has anyone compared these two subs for performance?
netconcepts is offline
post #2 of 3 Old 07-22-2012, 08:06 PM
Archaea's Avatar
Quoted: 3071 Post(s)
Liked: 2680
Depending on your use intent - I'd advise canceling your order, and purchasing a more capable subwoofer.
That BIC V1220 isn't much of an upgrade from the velodyne you had and it sure isn't flat to 23hz.
http://www.avsforum.com/t/1391243/bic-v1220-and-bic-f12-omnimic-frequency-response-graphs/0_20
The BIC V1220 represents a good value at $200, but a better value is found in the $300 sale priced Klipsch RW-12D if you want extension to 22 or 23hz.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
RW-12D FR graphs
http://www.avsforum.com/t/1390563/klipsch-rw-12d-omnimic-frequency-response-graphs/0_20
Archaea is offline
post #3 of 3 Old 07-23-2012, 08:48 PM
JimWilson's Avatar
Quoted: 1472 Post(s)
Liked: 1937
+1
For $300 the RW-12d is pretty hard to beat for HT.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
Bic Venturi Subwoofer V1220
