advice SB12-NSD vs. VTF-2 MK4 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 64 Old 10-09-2012, 12:48 PM
BeeMan458's Avatar
Liked: 813
Low level programming confuses the heck out of digital data, especially when using an analogue line. It doesn't know if it's digital or analogue or if it should go left or right and ends up getting lost. Duh! tongue.gif
j/k
BeeMan458 is offline
post #62 of 64 Old 10-09-2012, 01:39 PM
Moderator
rboster's Avatar
Quoted: 1118 Post(s)
Liked: 1137
Originally Posted by IamAnoobieCheez View Post
For dual sub, I don't think going with a Y cable is a good idea = DATA LOSS
Not good. Stick with a single sub.
Meanwhile, I do like my SVS SB12-NSD. No complaints.
I defer to Mark Seaton of Seaton Sounds, who has suggested the use of a y adapter for uses like this.
http://www.seaton-sound-forum.com/post/Two-New-Submersives-One-SW-Output-4849441
He also goes on to recommend reasonably priced cables too. I would think that on the topic of subwoofers and low frequncey signals, Mark would be considered a well respected expert on the topic(s).
FS: HDBaseT HDMI Cable extender Kit (up to 100 ft) for $75 : http://www.avsforum.com/forum/210-vi...l#post52653465//
rboster is online now
post #63 of 64 Old 10-09-2012, 02:57 PM
wichitadisciple's Avatar
Originally Posted by Purpose View Post
I dont think anyone disagrees with that. I called SVS and HSU and the recommended larger subs as well.
The issue here is that after I posted that I was happy with my sub in my space and didnt need anything more powerful, the response was essentially: i) other people (who dont live with me and have no bearing on whether I am happy with my setup in my space) have been unhappy with larger subs; and ii) the OP doesnt know what he is missing because he hasn't heard anything larger. Hence the discussion re: goals/ need.
I know I'm 2 months late for this discussion... BTW, I'm glad you like the SB12, SVS makes awesome subs. I was gonna recommend getting the PC12-NSD. The reason for that is the footprint, I think since it's a cylinder and not a box, that it would have a smaller footprint. But then again, the PC12 is ported and is louder then the SB12... which would have been bad in your current living situation.
wichitadisciple is offline
post #64 of 64 Old 10-09-2012, 03:04 PM
I was told the same thing when I asked about a 2 sub setup. To boil it down.... with the frequencies that subs are dealing with I was told that cables don't make much of a difference at all. The difference in sound between a $30 cable and a $100 cable is negligible. I could have been told wrong.... but if I was it was by someone on this forum tongue.gif
Hsu Vtf2 Mk4 , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer
