Randy's DIY Subwoofer Isolation Riser - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-29-2012, 08:53 PM - Thread Starter
RandyDee's Avatar
After getting my Paradigm Studio SUB 12 and listening to some bass-heavy music and movies it became clear that I need some sort of isolation riser for it since it stands directly on the hardwood floor and it frequently produces some pretty annoying rattling. First I was trying to find some commercial risers like Auralex Subdude or Gramma but their sizes are no good. I wanted only one platform that would nicely fit my sub. So I decided to build my own. Got some ideas on this forum and elsewhere and here's what I did:
1. First, I got some material:
2. Tools needed:
  • Utility knife
  • Electric staple gun
  • Tape measure
  • Scissors
  • Marker
  • Ruler
3. Cut the under-carped pad and glue it on one size of MDF:
4. Glue and staple the sides of the runner carpet to the MDF:
5. Cut and glue the carpet on the front/bottom side of the board:
6. Finish the back/bottom side of the board:
7. Finished board:
8. Board installed with temporary legs made of hard foam (I know, doesn't look nice...but works great!):
RandyDee is offline
post #2 of 11 Old 07-29-2012, 09:53 PM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
pitviper33 is offline
post #3 of 11 Old 07-30-2012, 06:47 AM - Thread Starter
RandyDee's Avatar
Originally Posted by pitviper33 View Post
Yes, it worked very well, I was quite surprised. All of the rattles were eliminated and now whatever rattles, it's airborne. The hardwood floor has no reason to vibrate anymore. Now I can finally enjoy "Bassotronic" or "Bass Outlaws"...
RandyDee is offline
post #4 of 11 Old 07-30-2012, 07:08 AM
flickhtguru's Avatar
Liked: 110
OP... I did the same basic thing. Spray paint the foam black like I did and you won't even see them they will blend in with the platform.
http://i1264.photobucket.com/albums/jj489/flickhtguru/DSCN2686.jpg
http://i1264.photobucket.com/albums/jj489/flickhtguru/IMG_0268.jpg
Shawn
flickhtguru is offline
post #5 of 11 Old 07-30-2012, 07:17 AM - Thread Starter
RandyDee's Avatar
Looks great, I like that. I already did try to spray paint some foam leftovers but then when I slightly squeezed them, a bit of the paint fell off them (and after serious squashing almost all of it)...you haven't noticed anything like that? Just curious...what kind of paint did you use?
RandyDee is offline
post #6 of 11 Old 07-30-2012, 08:08 AM
KnifeGuy's Avatar
Looks good. Nicely done tutorial too.
KnifeGuy is offline
post #7 of 11 Old 07-30-2012, 09:45 AM
Liked: 110
No i didn't have any fall off. I used flat black spray paint either Krylon or Rustolium and I did 3 coats to fill in all the pours. BTW my foam is 2" thick and the platform is 3/4" MDF painted flat black with a roller.
Shawn
post #8 of 11 Old 08-04-2012, 03:36 PM - Thread Starter
RandyDee's Avatar
And since these "temporary" riser legs made of hard foam worked so well, I'm gonna keep them. I just covered them with the same carpet and here's the final picture (not bad, I must say, I'm happy):
RandyDee is offline
post #9 of 11 Old 08-04-2012, 03:52 PM
matrixj3's Avatar
I make the pads out of dense rubber foam the one thats pliable and full of bubbles. Also use it as a damper for my projector and bluray player for vibrations.
matrixj
matrixj3 is offline
post #10 of 11 Old 08-04-2012, 05:45 PM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2984
Great riser, Randy. Very cost effective solution with the carpet padding instead of the more expensive closed cell foam that people often used. Looks nice, too smile.gif
Although, I am surprised when people use a layer of acoustical closed cell foam. Sound deadner is much more effective for stopping resonation, and generally cheaper than thick acoustical foam.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #11 of 11 Old 12-15-2015, 07:04 PM
Quoted: 58 Post(s)
Liked: 64
Fantastic! Put together similar riser, and it works and looks good too.
choombak is online now
