Could electrical power be the problem? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-01-2012, 01:54 PM - Thread Starter
swgiust's Avatar
Quoted: 26 Post(s)
I have 3 subs in my room. When I listen at low levels, they rock the room. But when I listen at theater levels, I don't
seem to get the same slam.
Is it possible I am just not getting enough juice out of the wall? How can I test for this? Would a voltage drain cause this,
but allow everything to still work? Like me projector and blu-ray player? If normal power is 120 volts, how low can that
go before components don't work?
I am guessing that my 3 subs, 7 amps, projector, tv, satellite and pre-pro are all on a single 15 amp circuit. I have never
had the breaker trip. Even when playing at extreme levels.
Thanks for the help.
swgiust is offline
