Advice for best dollar-for-perf sub within USD600 (BR concerts/Movies/CD = 50/40/10) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-02-2012, 09:37 AM - Thread Starter
sevenz's Avatar
Quoted: 65 Post(s)
Liked: 46
Fellow brothers of hifi!
Need some kind help on subwoofer as I'm quite a newbie to hifi. Previously on an entry-level onkyo HTIB S3200, and upgraded to my current set in May/Jun 2012.
Must say that I am already enjoying much much more as compared to my previous HTIB set. But was thinking of getting a better sub to better suit my current HT setup, but not too sure what to get.
Well based on room size, I know may need a bigger budget, but I guess I have to compromise. Can advise the best sub for the budget of USD$600?
Below are some details of my setup and listening preferences:
- Listening preference: Bluray music concerts/Movies/CD music = 50%/40%/10%.
- Room size: 19.7ft x 13.1ft x 8.5ft, but listening area is 13.1ft (L) x 13.1ft (W)
- Current HTS setup: Yamaha RX-V1900, Infinity Primus PC351 centre, Polk Audio TSI200 fronts, Cambridge audio S20 rears, Infinity Primus PS-8 SW.
Below is an illustration of my living room layout: (ll - denotes wall, x - denotes empty space - have to use xxxx as the website do not allow blank spaces...... )
(19.7ft)
llxxxxxxxxxxxxxxxxxxxxxxxx FL xxxxxxxxxx C xxxxx SW FR ll
llxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxll
llxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxll (13.1ft) (window panel on this side)
llxxxxxxxxxxxxxxxxxxxxxxxxSL xxxxxxx [sofa here] xxxx SR ll
============ xxxxxxx =========================
xxxxxxxxxxxxxxx ll xxxxxx ll xxxxxxxxxxxxx (13.1ft)
xxxxxxxxxxx(corridor to bed rooms)
sevenz is offline
post #2 of 4 Old 08-02-2012, 09:49 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
Room size is approx. 20' x 13' x 8.5 = ~2,210 cu.ft.
Questions:
- Where do you live (this may impact selection and shipping costs).
- How flexible is your budget?
The SVS PB10-NSD is a great sub. If you can find a gently-used one for a good price, it's definitely worth considering.
The Emotiva X-Ref 10 is a good music sub, but it doesn't dig very deep.
If you live in the continental USA and can afford to stretch your budget to $649 (incl. shipping), that'll get you the SVS SB12-NSD, a very well-rated sub.
eljaycanuck is offline
post #3 of 4 Old 08-02-2012, 09:52 AM - Thread Starter
sevenz's Avatar
Quoted: 65 Post(s)
Liked: 46
Questions:
Im in Singapore. Budget is kinda fixed as I've already spent quite a bit on this set, upgraded from a off-the-shelf satellite cheap onkyo set. So far all the components I bought are all used sets from fellow hobbyists.
sevenz is offline
post #4 of 4 Old 08-02-2012, 08:38 PM - Thread Starter
sevenz's Avatar
Quoted: 65 Post(s)
Liked: 46
I was reading and it seems some choices that suits my listening and budget are: SVS SB12, SVS PB10. HSU VTF-1, Xref 10, MJ acoustics Pro50 MkII, any M&K 10" sub, sunfire 10" subs.
Do u know which will be the most suitable choice out of the lot? considering listening preferences and room size.
sevenz is offline
