Please fill in my missing link.... (passive sub question) - AVS Forum | Home Theater Discussions And Reviews
Old 08-02-2012, 03:27 PM - Thread Starter
Tampa Tom's Avatar
I'm building out a new rec room above my garage. I'm using an Onkyo TX-SR606 that I have sitting around to power the 7 in wall speakers as well as the 2 outside speakers. My current dilemma is that I will have to build an enclosure in to the wall with a power outlet in order to run a powered home theater sub but I'd rather run an in wall passive sub. I'm trying to figure out if it's cost worthy to pick up an amp off of craigslist to power the subwoofer.
I was looking at this sub on Monoprice.com
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10837&cs_id=1083705&p_id=4928&seq=1&format=3#specification
and here is the back of the Onkyo sr606 receiver:
http://www.studio-22.com/onkyo/images/606-conexiones.jpg
I need opinions on whether or not I should just bite the bullet and build the wall enclosure for a standard home theater sub or if someone can fill in the blank on what I need to purchase in order to run this sub.
Thanks in advance.
Tampa Tom is offline
Old 08-02-2012, 05:46 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
The monoprice subwoofer, well based on specs its more of a woofer ....
How much are you willing to spend ?
How much space do you have in the wall ?
qguy is offline
