Bi-wiring and Subwoofer Problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-03-2012, 12:21 PM - Thread Starter
aranavs's Avatar
Hello all,
I recently bought a sub for my AV reciever (Sony str-dh810) but when I connect it, no bass comes out! No sound at all comes from the sub although it is on and connected properly to the AV reciever using a 1/LFE cable. I've tried everything to make it work, but I thought could having 2 bookshelf speakers Bi-wired to the AV reciever stop the Sub from recieving the bass?
Any help would be appreciated
Arran
aranavs is offline
post #2 of 6 Old 08-03-2012, 01:12 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4781
Originally Posted by aranavs View Post
Hello all,
Arran
Did you tell your receiver you have "large" or "full range" speakers (forget which way Sony goes) and not change to small? Did you tell your AVR you now have a subwoofer connected? Go thru the manual on setup....
lovinthehd is offline
post #3 of 6 Old 08-03-2012, 08:22 PM
Sonyad's Avatar
Quoted: 190 Post(s)
Liked: 111
Pull out your manual and the mic. You need to redefine your speaker setup, letting the receiver know you have a subwoofer and run through the auto calibration.
Sonyad is offline
post #4 of 6 Old 10-27-2012, 05:10 PM
keeshen's Avatar
Have you got this problem solved? i have a similar situation
keeshen is offline
post #5 of 6 Old 10-27-2012, 06:09 PM
lovinthehd's Avatar
Liked: 4781
Did you follow your manual for setup? Or after following setup procedure, nothing?
post #6 of 6 Old 10-27-2012, 07:11 PM
Bill Fitzmaurice's Avatar
Liked: 5684
Since he hasn't posted in well over 2 months one would assume that he did what he should have in the first place, read the owners manual, thus ending the problem.
Bill Fitzmaurice is offline
