Need help: SVS PC13 Ultra or PC12 Plus - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-05-2012, 10:29 AM - Thread Starter
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
My non-dedicated room is about 25x15, with 2 openings. I have had the SVS 20-39 PC+ in my theater since it was introduced, so it has the original driver and 525 watt amp. I very occasionally bottom it out. Right now SVS has the PC12 Plus for $100 off, making it $500 less than the Ultra. Will the Plus be enough of an upgrade, or should I go with the Ultra? I plan to use it crossed over from my mains (PSB Synchronys) at about 50-55Hz.
TIA for any help!
TL5 is online now
