Help picking a sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-05-2012, 09:47 PM - Thread Starter
20 inch zenith's Avatar
So I'm piecing together my first HT and have started with Energy V-6.2 tower speakers and the V-5.2 Center. This will be in a fully carpeted/furnished 21 x 20 basement, will be strictly for TV/Movies and I have a max budget of 700 (would prefer to be around 5-600 as I have to buy a receiver too...suggestions for that welcomed too smile.gif )
What do you folks think would fit this situation the best?
20 inch zenith is offline
post #2 of 9 Old 08-05-2012, 09:59 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
For your price range and room size, I would get this one:
http://www.outlawaudio.com/products/lfmEX.html
ack_bk is online now
post #3 of 9 Old 08-06-2012, 12:39 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2991
+1
The EX is an excellent sub, and it sounds great with my Energy RC-50s, RC-LCR, and Veritas Surrounds smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 9 Old 08-06-2012, 05:51 AM
skally's Avatar
+2 as well on the Outlaw EX.... fantastic sub, love mine!!
To save a few dollars to can take a look at these as well
Outlaw Plus
www.outlawaudio.com/products/lfm1plus.html
HSU VTF-2mk4
www.hsuresearch.com/products/vtf-2mk4.html
I'm bias thou as I would go with the PLUS over the VTF-2 as I know what the Outlaw can do wink.gif. You can always check the "B" stock at Outlaw as they can save a few dollars as well BUT they always sell fast so you almost have to be right on top of it daily to check.
skally is offline
post #5 of 9 Old 08-06-2012, 05:55 AM
pukemon's Avatar
Quoted: 276 Post(s)
Liked: 70
^^^^^^^ either or.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #6 of 9 Old 08-07-2012, 07:14 PM - Thread Starter
Thanks for the suggestions. I'll be reviewing the models mentioned.
If I were to up my budget a little bit would the Ryhtmik F12's be worth the extra money? Also wondering if getting dual subs in the 300-400 range might be a better option.
post #7 of 9 Old 08-07-2012, 07:46 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1301
The F12 is a sealed sub a won't have the output the others will in a room that size. A pair of $300 subs might give a more even bass response but they won't go as deep and generally won't sound as good. They're almost all boom with little control or definition. But boom is mostly OK for many movies. It's your preference.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #8 of 9 Old 08-07-2012, 10:37 PM
cel4145's Avatar
Liked: 2991
Agreed.
The F12 would likely be challenged in your size space at louder volumes. And I would not consider subs in the $300 to $400 range the same caliber as the Veritas setup you just bought.
For the price of the F12, either the HSU VTF-3 MK4, the Outlaw Audio LFM-1 EX, or the SVS PB12-NSD would be my choice, and you'll be very surprised at how well they perform for HT usage. Here are reviews for two of them:
http://www.audioholics.com/reviews/speakers/subwoofers/lfm-1-ex-review
http://www.audioholics.com/reviews/speakers/subwoofers/pb12-nsd/pb12-nsd-measurements
cel4145 is offline
post #9 of 9 Old 08-08-2012, 06:52 AM
skally's Avatar
I agree with Cel4145 as the HSU VTF-3 MK4, the Outlaw Audio LFM-1 EX, or the SVS PB12-NSD would be a great choice, not to mention when time/money allows to can add another.
skally is offline
